Weslo Pro Crosswalk 7.8 Treadmill Logo
daniel e cabral Posted on Nov 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The incline is stuck all the way up and still trying to go higher with no display
ernesto cuadra
Level 3:
Top Expert:
  • Weslo Master 12,223 Answers
  • Posted on Nov 21, 2011
ernesto cuadra
Weslo Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080883
Points
34431
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Finally you can get you answer Strong about if the problem:
1)Power supply 2) Elevation Motor 3) Main Controller Motor.Remember the Pcontroller Motor control 90% functions of the treadmill.
sincerely-
My Reebok Jet 200 is stuck at an incline
If your Reebok Jet 200 treadmill is stuck at an incline and you are unable to lower the incline to the 0 position, there are a few things you can try to fix the problem:
  1. Check the incline motor and make sure that it is properly installed and functioning. If the motor is damaged or not functioning properly, it may be causing the incline to remain stuck.
  2. Check the incline control board and make sure that it is properly connected to the incline motor and other treadmill components. If the control board is damaged or not functioning properly, it may be causing the incline to remain stuck.
  3. Check the incline cable and make sure that it is not frayed or damaged. If the cable is damaged, it may be causing the incline to remain stuck.
  4. Check the treadmill's belt and make sure that it is properly aligned and tightened. If the belt is misaligned or loose, it may be causing the incline to remain stuck.
  5. Check the treadmill's power supply and make sure that it is properly connected and functioning. If the power supply is not functioning properly, it may be causing the incline to remain stuck.
If you have tried all of these steps and are still having issues with the incline on your Reebok Jet 200 treadmill remaining stuck, you may want to consult a professional for further assistance. A treadmill repair technician will be able to diagnose the problem and recommend the best course of action to fix it.
2answers
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Sportsart treadmill error 7
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Sportsart 3000 treadmill problems
My treadclimber is stuck on a high incline?
This is the nature of the treadclimber, the decks are inclined until you step on them. In use they should drop with your footfalls to absorb the impact, then rise back up as your foot nears the rear of each treadle. If you would like more travel as you walk turn the dials on the shocks to a higher setting, for less travel turn to a lower setting.
Treadmill power incline stuck in upper postion after power outage
RUN inmediately the software calibration for diagnose, troubleshooting and fix it easy.
God bless you
2helpful
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Horizon t40 incline is stuck
Watch the videos:
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related11_27_2011_9_37_21_pm.gif
Watch the block diagram, main controller board ha 90% aprox of functions of the treadmill. sincerely.
Top Weslo Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
NOEL
NOEL
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
