You need to clarify a little . No heater , or do you mean there is no air coming from vents . This would be a heater blower motor problem . Or is there air coming from the vents but it's cold , no heat ?
fan switch is probly fried from worn out motor--or the heater core is bad--will need to take down dash to replace these--inspect ac evaporator also--details in a haynes manual
Well,you eliminated the resistor,so it probably means the blower motor has shorted out.Either that or something has gotten into the blower wheel and jammed it. If you can bypass the resistor and just put 12 volts into the motor,do it.But don't hold it long,as a direct short can cause a fire without a fuse to blow for safety. In other words,prepare to buy a new heater blower motor. don-ohio
Two things.........either it's a bad blender motor,or more likely,plugged heater core..Remove heater hose from near thermostat and heater hose from water pump,and flush from water pump side heater hose back thru the heater core and out the thermostat side heater hose with a pistol grip type water nozzle. don-ohio
First check that the blender door motor is operating.This should be a little box directly in front center of the console. When you adjust the temp control, the arm should move on the box motor. Probably though your heater core is plugged.Do a search for don-ohio and heater core and maybe the long tryped message will come up, if you CAN do a search on this site.I'm pretty new here, and don't know the `ropes'. ha! don-ohio
Electric box is motor straight in front of center console if you have floor shift,but anyway it's in the center.What's the problem? Need info. in order to help. don-ohio
Probably a vacuum motor on the blender door has gone bad or the vacuum line broken or fell off.Find the blender door motor and with engine running,wheels blocked and emergency brake on in park,check the motor's operation. don-ohio
That has a built-in `slip mode' on the gear. The works must either be stiff or stuck or the motor needs a new kit,or just install a new motor if the works inside are good. Not a hard job,really.Just drill out the motor rivets and bolt in the new one. don-ohio
