Question about Panasonic KX-T7633 Corded Phone
Registering a new cordless handset
How to register a KX-TCA 155AL cordless handset to KX-T7633.
Thank you.
  • Panasonic Master
  • 2,460 Answers
It doesn't exactly "register" but you turn it on via phone programming.
Just plug it into the headset jack, then select a button to program and press PROG (the button) and dial 67 enter.
When you press the button, the light will turn on and the display will say HEADSET ON. Pressing it again will turn it off.
Carl
Posted on Sep 28, 2008
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
The included handset and base unit are
preregistered. If for some reason the
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
Handset not registering with base
I've repaired thousands of these kx-tga400b phones and we have the only improved keypad that eliminates the common keypad problems for good.
Does the cordless phone have a 3 in the top right corner after it registers to 3? If so, then it is registering correctly. If it THEN consistently says "invalid, please register" there is definitely a problem with the main circuit board and it's not at all common. I've seen a few of these but it's a rare problem. We can fix it but I'm not sure how much luck you would have with any other repair facilities.
If you have the problem intermittently it's probably a bad RF module. That's a much more common issue.
Feb 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Nov 05, 2007 | Panasonic KX-TG6074B Phone
Panasonic KX-T7633 Corded Phone Logo
297 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
