Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Sear 1/2 horse power Garage door opener problem 41A4315-6c
My Problem is that all of a sudden it will not receive the signal from the different transmitters unless they are right under the door opener itself. is there a way to boost the receive signal setting on the 41A4315-6c unit itself or am I out of luck and need to replace the opener. the cost of the new board would probably make it better to replace the hole unit.
  • 504 Answers
YOU CAN BUY A CRAFTSMAN / LIFTMASTER / CHAMBERLAIN UNIVERSAL RECIEVER THAT PLUGS IN THE WALL.AND WIRES TO YOUR PUSH BUTTON.
Posted on May 29, 2010
I have an old Sears garage door opener 139.663900 that went dead this week.
you sure it has power going to it? the outlet it is plugged into is working for sure?
Jul 17, 2015 | Building Materials
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain half horse power garage door.Wall switch all of a sudden does nothing. made loud bang last time going up.Put latch back in above safety cord. Car remote runs motor, but doesnt raise /lower...
Sounds like your drive gear has stripped. Remove the cover from the motor unit and check the gear. It is white nylon and it will be obvious if it is bad. Sounds like a good time to take a good look at your door springs. That loud bang may have been one of the breaking.
Mar 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
The motor in the openner is not running at all, 1/2 horse power crafman. 315mhz garage door openner,model 139.53914D
Have you checked the house circuit breaker? Do the lights come on? Is the door stuck in the open position?
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of the buttons has a lock icon. Hold that button in for 3 seconds.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Garage door opener doesn't work with key pad or remotes
It sounds like for some reason the receiver has lost the stored codes for your remote transmitters. The wired button goes right to the opener so it continues to work.
On the back of the opener you'll see a small pushbutton. Press it and the indicator light nearby will come on. While this light is on, press the button on your remote. The light will go out and the code is stored. Repeat this for each remote. The process is the same for the keypad, except that you need to enter your desired 4-digit code.
If this programming doesn't work you'll need to replace the receiver board. Like any other piece of computerized equipment, it can fail or be damaged by power line problems. But try reprogramming first, as that's the most likely solution.
If this has helped you, please take a moment to rate the solution. Thanks for asking here!
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,084 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
