Question about Car Audio & Video
I have a 1997 BMW R110RT Motorcycle with the radio option. My battery failed and I had to replace it. After this it was necessary to imput the security code to reactivate the radio. Problem is that one of the degits will not imput to complete the code. I need to get the radio repaired or if possible replace with something modern. Unit has the volume and station selection as a remote from the handle bars.
  • racton4 Sep 29, 2008
    OK That is kind of what I though. How how do I retrofit a new model radio and make it work with the remote handle bar controls? What type of radio will work in this circumstances?
    Bob
    President:
  • 1,263 Answers
In most cases it's often more costly to repair it than to replace it. the only way you can save costs on repair is if you do the work yourself or have a buddy that knows how to do it, otherwise the labor costs are just not worth it. please rate this
Posted on Sep 28, 2008
  • Ronald Mueller
    Ronald Mueller Sep 30, 2008
    when you pruchase the radio you can also get a harness plug that will match the cycle to the radio. you can generally go to an electronic store for this or a car audio or bike shop for the plug. this way you don't have to hard wire anything just unplug and plug the new deck with the adapter plug into the main harness and the remote on the handle bars will work just fine. just be real specific on what bi9ke you have and what the new stereo will be and they will match it. please rate this......thanks if you need to ask me anymore question to this post are some other problems just click on my user tab. good luck
No spark already replaced coil an brain box
Hi, Mike if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue, please visit the websites below. Good luck and have a nice day.
R1100RT No Spark Please Help BMWSportTouring Forums
Help My new R1100S died and has no spark
1993 2000 BMW R1100RT R1100RS Service Manual Moto Data Pr BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
Hints and advice for BMW bike motorcycle owners K1 K75 K100 K1100 bulb...
Jan 02, 2014 | 2001 BMW R 1100 R
Why engine could not start after a long parking?
Hi, Christian if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue please visit the websites below. Good luck and have a nice day. R1100rt will not start
http://forums.bmwmoa.org/showthread.php?51456-R1100RT-or-R1150RT
https://www.rbracing-rsr.com/downloads/BMW_R1100(RT-RS-GS-R)_Repair_Manual.pdf
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Jul 11, 2013 | 1998 BMW R 1100 RT (ABS)
1100 backfire my rt was running perfectly it went for service at bmw agent since then it idles rough and backfires on overunhave they messed with my engine management progam
Hi, Louis and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
RT 1100 backfire burp or
R1100rt back firing
Jun 13, 2013 | 1997 BMW R 1100 RT
I just brought a 91 R100 out of storage after 5 years. Opened fuel tank with channel locks and found corrision (rust) did not smell like gas. Fuel tank valves were left open to reserve. The battery is...
Hi, Thatsgood2 if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
Question re 1991 R100 Vintage BMW Motorcycle Owners
1970 1993 Bmw 2 valve Twins R45 R50 R60 R65 R75 R80 R90 R100 Motorcycle...
http://www.k100.biz/pdf/FAQ/FAQ_K100_tips.pdf
Aug 03, 2011 | 1991 BMW R 100 R
NO SPARK/CURRENT COMING OUT FM SPARK PLUG,ACCIDENTALLY TESTED IGNITION SENSOR WITH BATTERY KNOWING IT WAS THE STARTER
Hi, Anastacio if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
No Spark Diagnosis Motorcycle 4 Wheeler Starting Issues Using Multimeter
BMW Service BMW R1150R No Start
Bmw r100 service manual
May 16, 2011 | 1982 BMW R 100 RT
I have a k 100 rt, its been stood for 10 months, have charged the battery, the engin e spins but will not fire ?????
Hi, Jason if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
http://xlforum.net/vbportal/forums/archive/index.php/t-39135.html What to do When Your Motorcycle Won Start
http://www.carlsalter.com/download.asp?p=298
Bmw k100rt owners manual
Apr 28, 2011 | 1996 BMW K 1100 LT
1997 bmw r850r engine lost power ran rough missing backfiring fill of fuel spark plugs looked ok
Hi, Julie_gore136 and the usual suspects are:
http://www.ketchum.org/BMWmc/R1100.pdf
http://forums.bmwmoa.org/showthread.php?26358-coils-and-wires 1993 2000 BMW R850GS R850R Service Manual Moto Data Projec BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
Nov 22, 2010 | 1997 BMW R 1100 RT
I was looking over the 1983 R100, just acquired, and could not tell where the oil filter is? Also it hasn't run for at least 2 years. The start sequence I imagine is: clean gas tank, check for rust. pull...
Hi, Stevekearney if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
For more information about your issue and free downloads that you need please visit the websites below. Good luck and have a nice day.
https://answers.yahoo.com/question/index?qid=20121211114207AA8Remh
An Old BMW Airhead Comes to Life
Apr 19, 2010 | 1983 BMW R 100
Bmw r1200rt fitted with 2000 series professional radio,displays radio in window but wont opperate .Tried disconecting battery 48 hours,tried disconecting battery while ignition and radio on for 1 hour...
Hi, Lylespears for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
R1200RT radio problem BMWSportTouring Forums
FM Radio does not work
https://www.tradebit.com/filesharing.php/search/0/bmw+r1200rt BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
Jun 20, 2009 | BMW R 1200 RT Motorcycles
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
