Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Intele Clean It is constantly in the red. I changed my bag and still its in the red I vacumed in one spot for 20 min, Whats Wrong?
  • mkm7c Sep 28, 2008
    Even when i have the intell feature off, it is still in the red and flickering back and forth. And I lost my owners manual. Would help if they had one posted online.
Every time you change the bag you should clean the eye. The eye is inside the tube behind the bag collar. Just use a lint free cloth and wipe all around inside the tube. That worked for me!
Posted on Mar 22, 2009
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
My Vacmaster Pro 130 does not vacuum. What is wrong?
Karen, I am the social media coordinator for ARY VacMaster. Most times when this problem arises with a new machine, it's because there are packing spacers on the under side of the lid that weren't removed. Pull those off and try again. If that doesn't work, Give our technical support department a call at (800) 821-7849. You can always "like" us on Facebook (www.Facebook.com/aryvacmaster) and ask questions to us directly there too. Hope this helps. You can contact me there for quicker answers. :-)
Jun 04, 2012 | Vacmaster Pro 130 Vacuum Sealer Food...
My vacum will not start a red question mark lights up. Can this be fixed?
This light indicates the bag needs changed. If you've done that, The possibilities are a clogged hose, clogged elbow at power nozzle, or on certain models a bad Control Valve Assembly. If yours has a dial on top, turn so the smallest dot lines up with the arrow. If it doesn't have a dial, you don't have to worry about a bad CVA. If you aren't using genuine Electrolux bags made by Home Solutions, then the bags pores will clog faster, which would cause the vacuum to shut off.
Jan 09, 2011 | Electrolux C101 Bagged Canister Vacuum
Not sucking and the perfomance indicator light is on
check the filters to see if they are clogged and the check the hose for cloggs
Feb 02, 2010 | Vacuums
Whats the best way to clean tarnishing chrome??
the best way is to use a commercial buffer....but if you are like most of us, and don't have one, you can try "Mother's" chrome cleaner with a chunk of "magic Eraser" It does a good job at removing the black spots without scratching. Hope this helps! Thanks, Rene
Oct 04, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby carpet cleaning problems
http://www.greatvacs.com/kirby%20instructions.shtml
Note: This is just a website i found with the instructions. Don't hold FixYa, or me liable. But it did look pretty spot on when I did a quick browse through.
Hope this helps.
Apr 30, 2008 | Kirby G5 Bagged Upright Vacuum
No suction..says bag full
There is most likely an obstruction somewhere in the system that is not obvious to you. Please inspect all hoses. I have seen a sock in a vacuum line before, it caused these same symptoms.
Jan 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Help me fix my LUX7000
Turn the dial down to its least sensitive setting and try that. If not you can call my office at 570-326-1731
Oct 20, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
71 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
