Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Bleach tray my bleach tray will not empty when washing whites. it won't accept any bleach at all. what cause this?
    Sergeant:
  • 409 Answers
can you check if there is anything preventing it from opening?
can you also supply the model # off your washer?
thanks
Posted on Sep 28, 2008
How do I get the bleach dispenser to empty?
Most of these dispensers are of the syphon empty variety. If it's got water in it, it's got water in it.
Feb 19, 2015 | Washing Machines
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
Been dealing with a smelly washer- tried the usual, bleach, vinegar, CLR.....it doesn't seem to have a lint trap.....is there one? where might it be?? Its old but works great other than this.....
Have you tried doing an empty 90 degree wash with white powder?
It does have to be white powder rather than colour powder or any kind of liquid, becauses only white powder has bleaching agents.
Add it helps if you leave the machine empty or clothes, towels etc.
Washing machine smells are usually caused by mildew, and a 90 degree wash with bleaching agents ought to help. If you do this about once a month it should keep the machine clear of mildew.
Jul 25, 2011 | Washing Machines
Re: Kenmore Elite Washer 45996-there is mold in detergent and softner container but more on the holes above it when I pull that tray out to clean it--it is very difficult to clean those holes upside down....
The most effective way to clean mold is with bleach. If you have an empty spray bottle, mix a solution of 1 part bleach to 4 parts water. Use the spray bottle to direct the spray at every affected area and let sit for about an hour. Now, put a small amount of bleach in each container (2 ounces) and directly in the tub itself. Run a full wash cycle with (no clothes in the tub) the settings for whites. When the cycle has ended you may want to run another empty cycle if you can still smell bleach to be sure no hidden residue gets on your colored clothes. Be careful when spraying the bleach you don't spray towards yourself.
Nov 30, 2010 | Kenmore 45996 Front Load Washer
Water left in bleach tray as well as bleach
There are multiple soleoid valves which run water through this tray. The valve connected to the bleach compartment is not functioning properly.
You can see these valves on back top of machine after raising the lid.
More info, let me know.
Charlie
Aug 27, 2009 | LG WM-2277HW Front Load Washer
Bleach wont drain during washing
You may have a clog on that side where the water comes into it, or the dispenser valve is not opening that side.
There is a service sheet inside the bottom of that front lower access panel on the right side wall, you can go through the diagnostics to test the water flow to that side of the tray.
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
