Question about JVC Everio GZ-MG21 Camcorder
Transferring footage to pc
I need to capture footage from camcorder to avid liquid. I would usually use firewire to do this, but this camcorder does not seem to have the connection. Is there a way to do this through USB
  • 4,889 Answers
First plug in your USB cord to the comp and you'll see the options play on pc, pc connection, etc. Select CREATE DVD! (You won't be able to see or select any of the files you are going to import, oh well.) You should see the regular screen pop up that says import, create, view pictures. Click IMPORT PICTURES. It will automatically import both pictures and video. For file name write something you can easily locate, ex: AAAAAAAAAAAAAA (you can change it later) Then open MOVIE MAKER. Click on IMPORT on the upper left hand corner and you'll see their demo video listed. Click on picture and video files on the bottom right hand corner and select ALL FILES. You should see what was downloaded!!! YAY!! I haven't burn a DVD yet but the files are there and the program should do it from there!
Posted on Sep 28, 2008
Hi i don't know how to connect my PV-GS29 to my pc what should i do? d u need a firewire to connect?
Yes ... you need a firewire port if you want to capture your video to the online for a firewire pci card or if you have a laptop you may have one already installed if not you can purchase one in pcmia format to capture your footage to pc.
Aug 24, 2011 | Panasonic PV-GS29 Mini DV Digital...
HI There I have an old camcorder the Model is a JVC GR-DVL 150E i have some very old footage on the camcorder tapes, i never ever got around to transfering the footage on to vhs video tapes! but now i...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
Jun 27, 2011 | Cameras
I got Sony Handycam DCR-HC30E/HC40E. But I've lost it's CD-ROM Software. So how can I transfer Videos taken to my PC with Windows XP? Sanjaya
Use a firewire cable to connect the camera to the PC. Open Windows Movie Maker on the PC.
Capture the required footage.
Feb 08, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Do i need a cord to transfer my canon ax h1 footage to my computer?
Yes you need a IEEE 1394 (FireWire/i.LINK) cable to connect your camera to your computer.
Your computer also should have a Firewire port to connect this to your computer.
Else if you have a video capture card then you can connect the video out cable and capture the video from the camera.
Jan 03, 2011 | Canon XH A1 Mini DV Digital Camcorder
I have a Samsung DV-D381 MINI Camcorder. What
OK there are NO cables as such for that PC, as of normal, to get Video into this machine you will have to use either, a USB TV/Video card, and use the AV inputs. OR put a Video TV/Video Capture card into a PCI slot, and again use the AV inputs to connect via. The you will have to use the AV leads Yellow, Red & White, OR the SVHS port if available. You will also need software to record the video stream, If you camera has FireWire then you could install a FireWire Card into a PCI slot and hook you via that, you will still have to use software though. Sometimes the camera, has proprietary software to edit and work with the Video from the camera, usually via FireWire. To get said software go to the manufacturers web site, and download a copy.
Mar 15, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
I want to copy video footage from the tape to the sd card.
You cannot transfer the video from Mini-DV to SD card within your camera as your camcorder does not have this feature. If your purpose for finding this function is to transfer your footage to your computer, you may try using the firewire port in your camera to connect it to your pc.
If you need help with the firewire connection, feel free to post a follow up.
Hope this helps!
Nov 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Jun 17, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Scrambled footage
if you are captureing through the fire wire port, it could be the port is bad. Just to make sure, see if you can get ahold of a "Blue Box" one of those analog to firewire converter boxes, and see if it comes out clear then. if it does then I am 100% sure that it is the firewire port.
Feb 20, 2008 | Canon XL1S Mini DV Digital Camcorder
JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
Feb 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
JVC Everio GZ-MG21 Camcorder Logo
108 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
