Serial # XC52811822, purchased 7/24/2005
Sounds like the pressure switch is stuck its located inside the washer it has a small tube on it that is connected to the pressure chamber on the outer tub these block up with old soap ext and you have got to take the tube off and blow or unblock with a small wire
I checked the pressure switch tube and it was clear. I observed the washer's cycles again and discovered once the heavy wash part finished the washer stopped tumbling and advanced through the wash and light wash sections in 1.5 minute instead of the 12.7 it is suppose to do. Once the rinse began the rest of the cycle worked correctly.
