Question about Metrologic Instruments MS9535 VoyagerBT Barcode Scanner
Ms9535 bt not reading barcodes.
Whenever I attempt to scan a barcode, it makes a brief humming noise and doesn't respond. When inactive, the left blue LED and the the orange light above the Bluetooth logo blink on and off. How do we fix this? Thanks.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Posted on Oct 22, 2008
No. it mean that you caned barode not passing to the host, you need to defult the canner and scan th bluthoot address and try to scan agien. plz remeber to pulg the cabel to the host other vise it's gives same results
Posted on Apr 01, 2009
I changed the battery in my ms9535 & now it doesnt scan
First ,make sure to let it charge over night. Second, you may need to scan the bluetooth barcode located on the top of the charging cradle. This will tell the scanner which base to communicate with. If the charging cradle has a solid blue light, then the bluetooth connection is good.
Aug 07, 2014 | Metrologic Instruments MS9535 VoyagerBT...
MS9535 BT Bluetooth Wireless Barcode Scanner mac
barcode scanner are just plug and play intallation... they just replaced your keyboard... but for your your assurance check or visit their site... have a look on this site www.metrologic.com/ms9535
Nov 10, 2009 | Metrologic Instruments MS9535 VoyagerBT...
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Replaced battery - do I need to re-boot?
No you have to configure blutooth Adress, it's located on the bottem side of the scaner , scan that barcode and try to read, if it fall, get the user configuration gueid and enabel KBW OR USB ( first Chek Your communication method) if it's KBW trun to page 56 and scan Load keyboard Wedge Defaults , if it's usb trun to page 68 and scan enabel usb interface. if agein fall, scan the recall deafult and do the above steps.
mevan
MARC
Aug 04, 2008 | Metrologic Instruments Voyager BT MS9535...
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Having a lot of trouble with the bluetooth. Keeps becoming Disconnected
to solve tihse u have to reconfigure it using BT Adress, scan the BT adress bar code to configure it, if same problem pesist after discontined power repalce the batrry
Jan 09, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic Instruments MS9535 VoyagerBT Barcode Scanner Logo
1,641 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
