Question about Samsung BlackJack II Smartphone
Blackjack 2 won't turn on
My phone is fine when it is on, but if it turns off the on/off buttton on top won't do anything, so my phone is stuck off
  • 2 more comments
  • Casper420 Feb 11, 2009
    My BlackJack II just wont charge...i have the wall charger and the usb connector and even the car jack charger but it just wont charge...ill have it plugged in the computer and the computer says its not connected...it wont even turn on when it is connected to the computer or plugged in the wall...i don't no what to do
  • Anonymous Feb 26, 2009
    It worked fine yesterday, but today - nothing. I've trying removing the batter and the sim card. So far nothing works. I don't get it, I didn't change anything. I know the battery is fine and has a charge because I just tried it in a friend's phone.
  • Anonymous Feb 27, 2009
    My phone was dialing a number that I was trying to call and just froze, so I tried to hang up and everything and ended up after about 5 minutes of it not doing ANYTHING holding the power off button down. Now it won't turn on not even for a second. and I've left everything out (the battery and sim) for a while before trying it again!?
  • abshire_04 Mar 01, 2009
    My blackjack two has worked fine for the past few months, until today when it went dead and now I can't get it to turn back on. I have tried both a wall charger and usb charger with no luck. I've tried taking the battery out and still nothing... How should I proceed?
    Problem Solver:
  • 13 Answers
Hi svstskier,
This is actually a bug in the BlackJack II's firmware. If you power the BlackJack II off, but you're unable to power back on, try removing the battery for about 10 seconds, then reinsert the battery and power back on. The power button should work now.
(At the moment there's no permanent fix for this.)
Does that adequately resolve the issue?
Are you turning the BlackJack II off to conserve battery? While flying? Something else?
Thanks!
Jonathan
Posted on Oct 03, 2008
Samsung BlackJack sgh-i607 turned on yet reads ''phone off''
Follow these steps in order:
--- Enter the following exactly: *#1546792*#
--- The following menu (or something close) will appear:
1. Version
2. Preconfiguration
3. NETWORK & CALL SETTINGS
4. Internal
Simply press the number '3' on your keyboard or scroll down and select NETWORK & CALL SETTINGS.
1. Auto Answer
2. Power on Attach
3. Service Domain
4. Network Order
5. NETWORK MODE
Simply press the number '5' on your keyboard or scroll down and select NETWORK MODE.
--- The following options will appear:
Auto
GSM
WCDMA
Select AUTO
--- Press the red key to exit the menu.
You should see the phone acquire service and update the date and time.
Dec 07, 2009 | Cell Phones
Samsung Blackjack freezes
If you want, you can try doing a hard reset, which will erase everything that's not on external storages. Here is the hard reset procedure:
1. Removing the battery without turning it off.
2. Reinstall the battery and turn the phone on with navigator key pressed down.
3. press any key to skip to prompt.
4. press yes to reset the phone.
Good luck.
Oct 02, 2009 | Samsung Blackjack SGH-I607 Smartphone
I dropped my blackjackII and the power buttton on the verytop of the phone is jammed and not working.how do i get it to turn on?
The phone external casing must be disassembled and assembled back, checking keypad connector and refitting the keyboard in place.
If that does not work, then the keypad must be replaced.
Here a video on how to disassemble Blackjack, procedure is the same on BJ II : Samsung Blackjack Disassembly .
It is better having the job done at a phone repair shop, so that you do not risk to cause more damage to your phone.
Jul 08, 2009 | Samsung Blackjack SGH-I607 Smartphone
Phone will not charge.
Return to the carrier for warranty repair.
The charge port of the Blackjack starts to go bad and will not send the full charge tot the battery.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Jun 13, 2009 | Samsung BlackJack II Smartphone
On power up phone gets stuck on win moble blue screan. how do you do a hard reset?
Hello obrien615,
In order to reset your blackjack you will need to fallow the directions at the end of this post. Before you do that you need to know that doing this will wipe everything off of the phone. If you choose to continue keep that in mind.
1. Turn the phone off.
2. Power the phone on while pressing and holding Up.
3. You will be prompted to erase all data. Press 1 to erase and y to confirm.
Hope this helped
-Ryan
-Please Rate
Feb 18, 2009 | Samsung BlackJack Smartphone
Mic volume really low on Samsung Blackjack II
baby slobber is a dangerous thing... turns out the phone just needed time to dry internally. It took a while, but everything's fine now.
Jan 06, 2009 | Samsung BlackJack II Smartphone
Blackjack II will not start
This has happened to my Blackjack II and I've found if I plug it into the charger then plug the charger into the wall, the phone comes right on. It's a pain, however, if I'm not at home when it decides to do this since no amount of button pushing will turn it back on, it acts like the battery is dead (when I know it isn't!)
BTW, I've have to have my SIM card switched out twice and the battery replaced 4 times since I bought this phone brand new in February......
Aug 30, 2008 | Samsung BlackJack II Smartphone
Blackjack i607 stuck in "phone off"
Try doing a master reset. this will delete all of the data and settings but it may help. go to settings, push more until you see security, and then press reset. if not have AT&T send u a new one (if you still have a warranty) if you havent already you should try a soft reset before doing the master. soft resets leave all of your data intact. to do this: turn the phone on. after it is on fully, remove the battery and wait about 30 seconds, then reinsert the battery.
Jul 30, 2008 | Samsung Blackjack SGH-I607 Smartphone
Blackjack stuck in "phone off"
This solution worked for me: NJ
My Samsung Blackjack showed "Phone off" on the screen even after I switched on/off several times.
The fix: Turn the phone on and call your voicemail (i.e., hold "1" to connect to voicemail).
It will prompt you that the phone is off and that if you want to turn it on.
Press "yes" and Voila!
Jun 04, 2008 | Samsung Blackjack SGH-I607 Smartphone
Samsung BlackJack II Smartphone Logo
1,702 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
