Question about Pioneer Premier DEH-P960MP CD Player
Ive got everything hooked up right but the cd player wont come on
I can hook the red and yellow wires together and it will come on but when hooked up right i got nothin
  • 89 Answers
Sounds like the ignitionwire aint hooked up or turned ON...hehe...;)
Posted on Sep 28, 2008
Pioneer radio wont retain station memory
clock probably doesn't stay either.....sounds likke the wiring may be incorrect...there are 2 battery + leads on these radios...One is yellow...which should be hooked up to a hot lead that is hot all the time even with the key off( you could just run a wire to the positive side of the battery)..thios lead is the memory lead that keeps stations, settings, and the clock....then there is the red lead that is supposed to be hooked up to a switched positive lead...such as the accessory lead fron the ignition switch....it's a good bet that the red and yellow leads are hooked together and that they are hooked to a switched ignition lead right now...all you have to do is disconnect the yellow lead from where is hooked now and hook it to a hot all the time then your memory, and stations should be retained
May 10, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
My stereo wont turn on i dont know what the
hook up the ground and twist the red and yellow together and hook that up to a wire off the battery then try and see if the head unit comes on quick way to check and see if the deck will come on works for me. hope this helps,
May 10, 2010 | Alpine CDA-7892 CD Player
I installed a clarion cd player now cd plat doesn't shut off
THe red wire is to be connected to power from the ignition.Meaning this wire should only be hot, when the ignition is on..
Sep 07, 2009 | Clarion DB538RMP CD Player
Pioneer DEH-P5800MP CD Player not powering on.
did you try the fuse behind the wireharness. if so check the yellow wire and the red one for power. also check if you have ground on it. if you want to make things simpler try to connect the black wire to the battery neg. and the yellow and red together on the positive of the battery and see if it turns on.
Sep 01, 2009 | Pioneer DEH-P5800MP CD Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Installation
We can help you.Welcome to contact www.playpower.com.cn
Aug 21, 2008 | Car Audio & Video
Sony cdxm610
Red- Constant Power -
Yellow - Ignition power - 12v
Black - Ground
Blue - Ant & memory
Orange - Dimmer
All the wires that have 2 of the same color are speaker wires
ex - green, and green with stripe. The one with a stripe is the Negitive
In most cases the red and yellow need to be together to get the cd player to start if you dont have 2 hook ups for both constant and ignition powers.
The black ground can go to any bolt that is screwed into a metal grounded object. The blue and orange are not needed unless you have a harness that supports the dimmer and memory feature.
If you cd player works with this but wont keep settings or time, hook up the blue to the power so it can constantly save your settings.
All the speaker wires a total of 4 diffrent sets of 2 can go anywhere as long as you dont want to fade or bal your speakers if so you need to test them by hooking up 1 speaker at a time to find out where it leads to. GOOD LUCK
And
Thank you for your question
Aug 04, 2008 | Sony CDX-M610 CD Player
Kenwood kdc-119**
No, you have the battery wire hooked up to the ignition switch.
Here is the owners manual with wiring diagram.
http://inform3.kenwoodusa.com/manuals/KDC219.pdf
Yellow wire must go directly to fused HOT (battery).Not through ignition switch, red goes to switch.
Good Luck
Leadispenser
Jul 30, 2008 | Kenwood KDC-135 CD Player
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
How to install?What wires hook up to where?
Hi, Re the power wires - black is ground (or - of battery), red goes to the + terminal of the battery and the yellow would go to the Acc in the ignition switch of a car. If you are hooking it up on a spare "battery", you have to twist together the red and yellow and connect both to the + terminal. Good luck and kind regards.
Oct 10, 2007 | Pioneer DEH-P2000 CD Player
Pioneer Premier DEH-P960MP CD Player Logo
61 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
