Question about Roper RAS6233KQ Top Load Washer
Washer makes loud knocking noise
Hi
I have a roper washing maching that spins fine but makes a loud banging noise during any extraction cycle. This noise is different than when the load is off balance. The faster the spin the faster the noise. Any hints?
  • jch_01 Oct 05, 2008
    I have the same problem with my Roper top loading washer, different model. How do you go about fixing the bearings on it or getting to it all?
    Thanks
  • 943 Answers
HI thanks for your question. you could have something stuck in one of the holes, in the tub, or something caught in the pump, check those 2 . if need more assistance , get back to me. thanks the appliance doc
Posted on Oct 11, 2008
  • 4,889 Answers
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Posted on Sep 28, 2008
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
Amana top loader washing maching permanently tilted drum & loud banging during spin cycle
I guess you washed some curtains and blankets in it that it spun unbalanced. There are 2 things. One is the one of the suspension springs broke off. Another is the center post is already bent. You may have to check inside. If you are handy, you can take off the cover and check. Suspension springs are dangerous when being replaced. You may have to wear a pair of goggles. With the centerpost, it is difficult to replace. I suggest you call a technician for this.
Jan 17, 2014 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
484 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
