Question about HP Officejet 5610 All-In-One InkJet Printer
5610 will not print on color paper
Every time printer jams with 56 lb color paper
    Novelist:
    Scholar:
  • 111 Answers
I'm wondering if the paper weight and/or size is exceeding the printer's specifications. The paper tray specs on HP's site says it will take up to 110 lb card stock, but as far as paper stock, it can take only up to 24 lbs. Have a look at the printer's product specifications page and see if this could be the issue:
Product Specifications page
Posted on Sep 29, 2008
HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
When printing in color, the color runs
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb), OHP transparencies, postcards*, letterheads,
colored paper, envelopes, label sheets, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray
Jul 13, 2010 | Samsung CLX-2160N All-In-One Printer
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
HP OfficeJet 5610 All In One alignment cartridges and no printing
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab101
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
