The printer looks ready, however there is a document in the que that shows deleting--printing. I can't get it to go away so other printing can occur
Do power drain . if not working , do hard reset . no>, go to printers and faxes , check the status of the printer there. if its showing <ready>, its ok ..
if its < deleting>
right click//cancel all docs.// resume//
if even naot solved..
start <> run<> services.msc<>print spooler<> double click<>select "automatic"<>select service status:started<>
now check functionality
workin great??
no? change the printer ..
thank u
If you have Vista, you probably have to run this with administator privilages (UAC). For XP and
older Windows operating systems, you can start and stop the spooler from the command prompt
(or Start Run).
net stop spooler
net start spooler
Should remove the document from the queue.
