Question about Kenmore 62622 Electric Dryer
Kenmore ultra fabric care dryer runs, but does not heat up Same as Christy's. Runs no heat, however, the exhaust vent is clear. Could this be the fuse or heating coil?
  • Anonymous May 14, 2009
    dryer runs but no heat
  • 32 Answers
Could be a thermal fuse,heating element or a heating element relay.if you pop the trim caps off of the sides of the console,and remove the 2 phillips screws in the corners and lift up console you will find a tech sheet inside.if you have a multimeter that you can check continuity with along with the tech sheet,you might be able to figure it out..good luck
Posted on Sep 29, 2008
Why won't my dryer heat up?
There are several reasons for no heating on a Tumble Dryer. The heating element could be faulty ( open circuit.) There are several thermal cut outs which can also go open circuit The only way to check is with a Multi Meter by a qualified service engineer.
May 26, 2012 | Kenmore Dryers
I have a Kenmore Ultra Fabric Care Dryer. It does heat up, but takes four times longer than normal to dry clothes and no lint is appearing on the lint filter. I checked for a clog in the dryer vent and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 08, 2011 | Dryers
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Kenmore-ultra fabric care gas dyer runs but no heat..gas is on..help
It is most likely the thermal fuse watch this video your unit is made by whirlpool and these are very common to fail http://www.youtube.com/watch?v=ajDWK7x1J5Q
Jun 20, 2011 | Kenmore 62602 Electric Dryer
Kenmore Ultra Fabric Care dryer Model/stock number 96595220 65952 Dryer shuts off all the time. Runs, heats, works, then just stops. This happens repeatedly. Please help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 659 Electric Dryer
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore Electric Dryer
check your fuses.one runs the dryer and other heat the dryer.
check to see if belt is broke or wire is burned off of motor.
Mar 08, 2008 | Dryers
check the thermal fuse the operating therostat and the igniter is this a gas or electric dryer
Jan 12, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62622 Electric Dryer Logo
1,178 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
