Hi, i have a 2.5 laptop hard drive and its bust. i want to buy a new one but the connections are different to other models. The one i have has 16 heads on! please help
    Novelist:
  • 169 Answers
What you're seeing is the newer drive technology called SATA. IDE is probably what you had before, and the drives are not compatible. If your computer had the "old" style drive, you need to get another IDE drive to replace it. SATA has to be supported by the motherboard, and also have the correct cables and connections in order to work.
In other words, if you just bought this drive, you got the wrong one - take it back and get IDE to replace the old drive ..worst case, take the old drive to the store and show the salesperson what you need :)
Posted on Sep 29, 2008
Asus laptop won't wake up
please provide what model this is, different series has different solutions.
Mar 26, 2013 | ASUS 15.6" Laptop - 4GB Memory - 500GB...
Can I replace the board with a new one? The polarity of the power for the hard disk has been connected mistakenly. The board is busted so I want to replace it with a new one from another hard disk with...
It will work if you are good with a soldering gun, but performance will not be the same and you risk loosing all of your data. I would recommend just buying a new one or paying a hard drive recovery expert to pull off any lost data.
Aug 24, 2011 | Computers & Internet
Unable to charge 700EB ebook-blue light keeps flashing-no charge taken.I am using AC adaptor.
About how old is the laptop? A common occurrence in older model laptops is the charge port becoming dislodged from the internal motherboard. The only real option you have, if this is the case, would be to back up your data with an external hard drive, and buy a new machine. If you do not have an external hard drive, but have access to another computer, then there is another option for data backup. Remove the hard drive from the laptop, buy an external enclosure (You can buy enclosures from your local Best Buy, MicroCenter, or electronics store) that fits your hard drive model, and transfer the data to the extra computer you CAN access.
However; if the laptop is fairly new, and the charge port doesn't wiggle or move at all (An indication of the piece becoming dislodged), then the problem could lie in the power adapter itself. Try purchasing a notebook AC adapter from an online site like Newegg.com or TigerDirect.com. They come with multiple attachments to fit a plethora of different devices, including a wide range of laptops
May 04, 2011 | Computers & Internet
Got a compaq presario 1700. The hard drive keeps on clicking and it runs really slow. So I'm thinking of getting a new hard drive with an operating system on it. Model number 17XL361. What is this? Is...
The clicking it the magneadle in the hard drive slapping against the spindle. Back up all your stuff to a flash drive and replace the defective hard drive. You cant buy a hard drive with the operating system on it. The chipset would be different from pc to pc. 17XL361 is your pc model number
Apr 30, 2011 | Compaq Presario Notebook
Hard Drive not recognized by laptop
The Hard Drive could have come loose from the SATA or PATA connection, or your Hard Drive could have simply died. If it is still under warranty; replace it. If it is out of warranty; open the external casing and check that the HD is connected and / or test the HD in a separate external casing or Desktop that you have. If it is connected and the external casing is working properly (or Desktop is booting properly and can read it), then you have a dead Hard Drive and will have to buy a new one.
May 03, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
X41 HDD
It makes no difference what brand of hard drive you have in the laptop, the original is going to cost you maybe 2 or 3 times or more the price of a generic drive.
Need to know the type from the laptop (4numbers) and also model, they are on the bottom sticker most likely.
post the details and I'll see what it can take.
Thanks
Jul 06, 2009 | IBM Computers & Internet
Need new laptop harddrive
Go to either bestbuy.com or compusa.com and look for the hard drive there. The hard drive will be cheaper going thru either of those places. Also check out pricewatch.com cause you can compare prices there. Also go thru google and check out the shopping results of the hard drive your looking for as well.
Lots of places to check and the hard drive will definitely be cheaper then going thru HP.
Jul 06, 2009 | Compaq Computers & Internet
Compaq 6720 Hard Disk replacement
Try seagate it's one of the best.
May 14, 2009 | HP Compaq 6720s Notebook
HARD DRIVE is not detected
Hi
Yes, problem with hdd you need to buy new hdd, no other choose....
Thanks
May 02, 2008 | HP Pavilion dv1000 Notebook
Maxtor hard drive needs a chip replacing
Unless you can find the matching chip and are good at soldering these small parts, it can be replaced.
Typically, I would suggest looking for busted harddisks (of the same model) and if their board was still good, just do a direct swap. I did this for a Fireball model HDisk.
Or if their board is busted, you can get the chip from them and, like I said earlier regarding soldering, solder it onto your Hard disks. This is considering that the only part busted was this chip.
Jan 21, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Computers & Internet Logo
David Payne
David Payne
