Re: How do i transfer a sound clip from my nokia E5 to my...
Connect USB cable, select mass storage, browse using computer.If your computer has bluetooth first do a pairing and after that simply send image via bluetooth.
Do the first part with the USB Cable. Connect USB cable, select mass storage, browse using computer in the folder that it usually saves sound clips(could be the Sounds folder on micro SD)Do the first part with the USB Cable. Connect USB cable, select mass storage, browse using computer in the folder that it usually saves sound clips(could be the Sounds folder on micro SD)
You can't post conmments that contain an email address.
It should come up as a new drive letter when you connect with a USB. You made need to contact NOKIA to get the software and install it on you PC.
Try going to the NOKIA site to locate software that will allow you to transfer data to and from your PC like phone numbers or pictures for example.
You got two ways to reset Nokia e5. Soft reseting : Soft reseting can restore Nokia e5 user setting and soft reset will not erase any data like image , sound, video. Press *#7780# on the screen and after few seconds soft reset will start. Hard reset : This option restores the original oprating system from the rom. Press *#7370# on the screen and after few seconds you may put the security code and reseting process will begin. It`s recommended to back up data before hard reset. BYE !!!
If the Nokia E5 shows invalid sim it's locked to network...You need to Unlock it...Visit the site Unlocking4u.com/nokia-e5/rs6wp9/ get the Unlock code and unlock t easily...
nokia E5 is symbian S60, yes, it supports java/.jar apps. and also .sis, just copy the application either cable or bluetooth, there are 2 ways in installing the file 1. via pc suite 2. on your phone,
This problem occur seldom.Anyway have you tried by inserting other battery ? First of all Insert good battery (not new but you can fully charge your old battery with multi-charger) connect USB and press Power button,after just you press the POWER button a sound will hear in your PC if the set is OK.So, if you can hear the detecting sound,you yourself can solve it.Just
Click here1 and follow the instruction.Or if you think that you could not do I can help via remote.Good luck
download NIMBIZZ from m.zedge.net in a jar format or download it in your pc and transfer through USB cable to your phone the file of NIMBIZZ must be in jar format download nimbizz from these sites www.mobango.com
Transfer music from a computer You can use the following methods to transfer music:
• To install Nokia Ovi Player to manage and organize your music files, download the PC software from www.ovi.com, and follow the instructions.
• To view your device on a computer as a mass memory device where you can transfer any data files, make the connection with a compatible USB data cable or Bluetooth connectivity. If you are using a USB data cable, select Mass storage as the USB connection mode. A compatible memory card must be inserted in the device.
• To synchronize music with Windows Media Player, connect a compatible USB data cable, and select PC Suite as the USB connection mode. A compatible memory card must be inserted in the device.
To change the default USB connection mode, select Menu > Ctrl. panel > Connectivity > USB and USB connection mode.
I hope this information will be helpful. Thank you for using FixYa!
Thank you Vlad but what if my laptop doesn't have bluetooth?
