Question about Hunter (25417) Ceiling Fan
Hunter ceiling fan barely moves
Three speed fan Barely moves at only ONE speed, slow! Fan is a few years old, but hasn't been used much. Does not have remote
  • buffaloe68 Jan 24, 2009
    Fan turns slowlyon all three speeds. worked fine on original start up. Wiring is correct. no Light. has a heat smell after running 2-3 minutes
  • buffaloe68 May 11, 2010
    when i turn the fan by hand, it coasts freely. Probably not the brng. fan starts up fine. probably not cap. If I remember right, Cap gives it the kick in right direction. I am thinking winding. How do you check the windings and is bench repair economical?
    buffaloe 68
  • 46 Answers
check if the fan turn freely if not then it is most likely a stiff brg,if it does then it could be a capacitor failure or faulty winding in the motor
Posted on Sep 29, 2008
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Why my Hunter Ceiling Fan does not work?
Its unlikely that the fan is on a separate feed from the breaker box than the rest of the outlets in your room but you never know. It would not hurt to check all of your breakers. If the fan and its light are controlled by the same wall switch then the wall switch may have went bad. Within the fan there are separate wires for the fan and the light so both of them would not go out at the same time. It makes more sense that the problem is at your wall switch.
Jul 14, 2014 | Hunter 25872 Sojourn II Brushed Chrome...
Hunter 23852,L-black to red-hurricane speed,black to yellow-almost hurricane,black to gray-very slow,hardy moves air,installed westinghouse 6A125vac switch,same speeds,how can i get a comfortable medium...
Sounds like a good ol' American made Hunter Original to me. BEST and most powerful residential ceiling fan (high quality) ever made. The RPM spec is 200-160-50 for the respective speeds, moving 10,500 CFM on high speed. Most ceiling fans barely crack 5,000 CFM. they were built for Brute Force Air Movement and they really don't do well for small spaces. The best solution I have for you is if you have a Wall switch for this fan, to install a Hunter Original Wall control or remote control.
Both controls will lower the Medium speed to about 100-110 rpm, which should be much more comfortable for you.
Because the Hunter Original (I know your fan is an American made unit by your wire colors) draws more current than other fans, the Original controls are the only controls that are designed to work with your fan. Other controls do not have the current capacity for the Original motor.
Also, are you aware your fan uses oil?
Aug 22, 2010 | Hunter 23852 Classic Original Ceiling Fan
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
Sep 22, 2009 | Dryers
Fan makes grinding noise when on speeds two and three. . . sounds fine on slow
The bearings are wearing out, speeds two and three are exerting enough force that the bearings are grinding, slow speed does not have enough force to do this. Soon enough, slow speed will make that noise and the fan will ultimately stop working. Have an electrician come in to look at it, if it is still under warranty, call Hunter.
Sep 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
My hunter douglas fan has a remote which we use for everything. There are three settings on the remote when we push the one for high the fan is barely moving.It moves very very slow on all of the speeds....
I have the opposite problem.  My fan turns on during the night at high speed and sometimes turns on the light,too!  I've changed the frequency 3 times, but have to pay someone to do so, so I've given up and just unplug it at night.  My problem, so someone tells me might be that mine is not grounded.
Jul 04, 2008 | Heating & Cooling
Hunter (25417) Ceiling Fan Logo
1,502 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
