E537
The front aligning plate does not reach home position when the front align-ing motor (M3) is driven for a specific time.
The front aligning plate does not leave home position when the front align-ment motor (M3) is driven for a specific time.
Possible causeThe front alignment motor (M3) is faulty.
The front aligning plate home po-sition sensor (S6) is faulty.
The sensor connector is disconnected or has anopen circuit.
The front alignment motor relay harness if faulty.
The frontaligning plate is subjected to an abnormal load.
The finisher controller PCBis faulty.
Remedy1)Front aligning plate home position sensor (S6)Check the front aligning plate home position sensor (S6).
Is the sen-sor normal?NO:Replace the sensor.
2)wiringIs the wiring between the finisher controller PCB and the frontalignment motor (M3) normal?
NO:Correct the wiring.
3)Front aligning plateIs the rack riding over the collar of the roll?YES:Correct it.
SOURCE: ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
