On my tv the standby button just flashes and the tv won't switch on. i've tried unpluging from the mains and trying again a while later but the same continues to happen. Any ideas what can be done?
  • theolearys Sep 28, 2008
    My TV is approx 8 years old and is a cathode ray style. does your solution still apply to that type of tv? Sorry i'm a complete novice and know nothing about this subject.
  • 706 Answers
Have you checked the projection bulb? They have a finite life expectancy so that may be the problem..
Posted on Sep 28, 2008
  • Rick Gelin
    Rick Gelin Sep 28, 2008
    oops...No it does not.. What is the brand and model number ? I made an assumption your tv was a different type of projection TV.. Please provide a brand and model and I may be able to provide some incite..
My technika lcd40-920 tv wont turn on standby flashing blue to red i held power in 30secs n stopped flashing but still wont turn on why some one said its trying to update but not sure can u help
How long have you had this TV? If it is under 12 months, get it fixed under the guarantee. If you have an extended warranty, use that to get it fixed.
I would suggest that you switch everything off, remove all the cable from your satellite box or games console and everything else, then switch off at the mains and unplug the set.
Now press and hold the power button on the TV for 30 seconds.
Now plug the TV into the mains again and use the TV button to switch on the set. If the lights continue to flash, then it's a repair job. If the lights are steady but there's no picture, then switch it off using the TV button and reconnect the aerial cable first and try it again.
Once you get a picture displayed, you can begin to reinstall all of the other cables until everything is working again.
Apr 13, 2015 | Televison & Video
My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Feb 24, 2013 | Sharp Aquos Televison & Video
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I've had several power cuts lately , now my tv is
Hello rogerstanila,
if you have tried unplugging it for a while and if there is still no change then it could be your main board. Unfortunately to fix this could be costly. See if you can find a repair tech that will do a diagnosis for free. But there has quite a bit of problem LG tv's being stuck on standby especially the LCD tv's, Other than this there is not much you can, maybe changing the battery of the remote and just keep trying to click on and off. If it is plugged into a cable box, try unplugging all of that for a while. Leaving it unplugged for a day won't hurt. If nothing else then it could be your main board. You could replace it but as I said before it could you couple hundred dollars. Hope this some what helps.
-Joe
Aug 30, 2011 | LG Televison & Video
Tv turns to standby then when i switch it on nothing happens then 10 second or so later the standby just flashes
unplug tv for 3-4 hrs then try again. if that doesnt help you may have a bad powersupply.
Mar 21, 2011 | Televison & Video
TV will not switch out of standby
Unplug,replug the tv an hour later,let the tv reset itself,might work again.
Apr 26, 2010 | Philips Magnavox 27MS343S 27" TV
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
