Question about GE GTS22WCP Top Freezer Refrigerator
Runs and freezes than goes into defrost mode and never goes back to freezeing
My refrigerator goes into defrost mode after it freezes than it won't go back
to freezeing unless we turn it off fore awhile. What is causing this?
  • 943 Answers
HI .thanks for the question. I think your problem is with the thermostat. It gets cold shuts off , and does not come back on . I would replace the thermostat. thanks the appliance doc. please rate my answer.
Posted on Oct 07, 2008
My GE does not freeze nor does the refrigerator work all my food defrosts and goes bad. I unplugg it and plug it back then it starts freezing again. But after maybe two days it stops working again.
may have a faulty thermister device. This could be telling the freezer to go into defrost mode or it might be the timing circuit for the defrost cycle.
Worth getting it checked out by a licensed fridge repair person.
Mar 12, 2016 | GE Refrigerators
Freezer fan runs not freezing . seems to be locked in defrost mode
read the manual book of the freezer ,,,and see if ice is not blocking the way......
Nov 20, 2015 | Amana Refrigerators
Refrigerator-freezer won't freeze
I think the fridge is low on gas, or the defroster is on all the time
Mar 24, 2013 | Whirlpool Refrigerators
No display
1) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic function of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
2) Touch the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
3) Press the "Express Freezing" key as well as the "Colder" key of the Freezer Temp function together while in Test Mode 2 and hold for 3 seconds. The refrigerator will go into Test Mode 3. Test Mode 3 allows diagnostic operation on the compressor and freezer fan off, stepping damper close and defrosting heater on.
4) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and maintain for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
5) Unplug the blog798088-troubleshooting-lg-refrigerator-defrost-cycles.htm&opts=1,3,5Lg refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
Oct 19, 2012 | LG LFX25961SB (247 cu ft) Side by Side...
Kenmore refrigerator won't cool
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 27, 2011 | Kenmore Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
MY MO GD22DFXFN02 REFRIGERATOR FREEZES UP AND THE COMPRESSOR DOES NOT SHUT DOWN. THE PROBLEM ABATED AFTER I SHUT THE REFRIGERATOR OFF AND RESTARED IT AFTER SEVERAL HOURS AND IT CYCLED ON AND OFF FINE FOR...
Yes, it is most likely the defrost timer, the timer isn't running anymore, the evaporator coil freezes up and your problems begin. Hope this helps
Oct 07, 2009 | Whirlpool Refrigerators
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Nov 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
GE GTS22WCP Top Freezer Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
