Question about HP PAVILION A6230N DESKTOP PC
Router problems My PC will not recognize the router anymore. It had worked fine for months. I have checked the modem...good. I have checked the router...still sends signal to laptop. I added a new net card, still no luck. Any ideas?
  • rpalaparthi Nov 20, 2008
    ihave same problem as above. i have not yet replaced the netork card. But the PC suddely recognizes the network connection and starts working fine for a few minutes/hours/days, and suddenly stops. It is anyone's guess when and for how long it recognizes. This problem appeared atleast 3 times since Feb 2008
  • Rob
    Rob May 11, 2010
    Is it a wireless router or wired?
  • 748 Answers
I've seen many routers die this way. Belkin routers have a tendency to go intermitant before they die. If your computer can get onto the net when connected to just your modem, then the router is the answer.
Good Luck
Posted on Mar 21, 2009
2 months ago we purchased the NERGEAR88 modem/router, it was workin great untill today. I have my laptop hardwired to the modem/router and the internet works fine but the wifi does not work anymore, none...
Not having defined the problem very well it is hard to answer.
  1. Press the reset button on the back of the router for 10 seconds. This will reset to factory defaults.
  2. Check on the manufacturers website for a firmware update.
  3. Buy a new router.
NETGEAR Support Answer Troubleshooting Connection Issues
Mar 03, 2015 | Computers & Internet
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
MODEM NOT RECOGNIZING ROUTER
You need to check the router's admin page to make sure the DSL/Cable modem is being recognized properly. This can happen when unplugging the devices. Ck your routers user manual for login instructions. Should be default IP address of router typed into internet explorer browser then you need login/password (like admin/admin) then check the status to see if router/modem are talking to each other. Probably good idea to unplug both devices at the same time and then power back up. I can be more specific if necessary.
Hope that helps,
TankMurdock
Apr 24, 2009 | Trendware TEW-432BRP Wireless Router...
Router not working
Check the adapter definitions on your PC
Jul 13, 2008 | NetGear WGT624 Wireless Router
BELKIN ROUTER NOT BEING RECOGNIZE BY THE MODEM BOX
Hello, You can find the user manual for the router at this link.
http://www.belkin.com/support/article/?lid=en&pid=F5D8231-4&aid=5926&scid=221
I would start out by resetting the Router according to the instructions in the manual.  Make sure you setup the security features of the router including changing the password.  If this does not work let me know and I will try to assist you further.  Good Luck - Dr. Know
Dec 21, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
HP PAVILION A6230N DESKTOP PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
