Question about Acer Aspire 5050-3242 Notebook
Problem: Acer Aspire 5050 touchpad not work inside xp abslutly but it work in safe mode the problem still not solved and when xp boot the thouchbad and keyboard stop to work but it work in safe mode some thechnical say that from safe mode i can disable ACPI couze the problem come from badness battry i wana to know the reason for the problem and how we can solve it , i wana to say that i have the original cd driver for the labtob
Found the below link along with this one by searching this in google: (search string directly below)
aspire 5050 keyboard does not work cannot turn off
Had a problem with when I booted the Aspire 5050 laptop. The keyboard and mouse would not work after windows xp loaded. I obtained the solotion from the following link and took the below steps -> http://www.tomshardware.com/forum/51337-35-keyboard-mouse-work-vista-login-screen
1) Followed the acer website link and downloaded the appropriate keypad drivers by looking for Aspire 5050 (5050 is the model)
2) Put it on a pin drive.
2.5) Unplugged the acer 5050 battery and still allowed the power cord to be plugged in (in effort to save time)
3) booted the acer 5050 laptop and kept hitting F8 to go into safe mode
4) logged into safe mode as 'Admin' and ran the setup from the drivers after inserting the pin drive.
5) shutdown windows
6) plugged the battery back in, turned the power on, everything works fine.
Thanks, Rusty!
Posted on Jul 26, 2009
Your problem is on battery! remove battery and use normaly!
Posted on Oct 13, 2008
Get new battery
Posted on Oct 07, 2008
Acer vista 5375z in safe mode
are you asking how to put it in safe mode? tap f8 at start up until presented with a boot menu. if you always load in safe mode, you can try the same approach only when the menu comes up hit enter on start computer normally
Nov 06, 2011 | Acer Aspire 5535-5050 Notebook
My Acer Aspire 5050 freeze up upon booting up. What can be did to end this?
Try to change or reseat memory RAM. If still got same problem, you need to change your HDD.
Thanks
Jul 18, 2011 | Acer Aspire 5050 Notebook
On my acer 5742-7645 my touchpad has stoped working?
Just check for the key combination on your keyboard (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
May 27, 2011 | Acer Aspire 5742Z-4200 Notebook
Acer Aspire 5535-5050 only starts in "safe mode"
when you get to safe mode try to do a system restore to a date that the computer worked............on xp it will give you a screen to enter safemode with yes or no options ........choose no to go diorectly to system restore...............if not xp look for system restore in the system tools folder on start menu or in control panel............the screen saver error is most likely because you are in safe mode.
Jul 19, 2010 | Acer Aspire 5535-5050 Notebook
Good Morning: I have an Acer Aspire 5920
As by your description, the FN F7 key combo did not solve the problem. Please restart the machine , press F8 then select from the list "Safe mode" then press enter. Then see how the Touch pad reacts in Safe mode. If it works perfectly in safe mode, we can assume you have a software problem that is preventing it from working in normal windows mode.
Please download and install the latest BIOS for your machine. The E525 has a issue where the TP just stops working, upgrading the BIOS solves the issue on the E525...
Acer Aspire 5920 3813 BIOS
Please install one of these drivers for the desired Operating system...
Acer Synaptics Device Driver Windows XP
Acer Synaptics Device Driver Windows Vista
Acer Synaptics Device Driver Windows 7
May 13, 2010 | Acer Computers & Internet
Can't get past the ACER screen when booting up? Please help.
reboot and keep tapping the F5 key for safe mode. when in safe mode do a system restore back to the point it was working properly.
hope this helps.
Apr 24, 2010 | Acer Aspire 5050-3242 Notebook
Acer 3000 battery
I had the same issue with a friends 3000.  Rebuilt with XP SP2 and updates as of July 17, 2008.  Works fine in Safe but once battery is installed touchpad locks up.  She is just leaving the battery out.
Jul 09, 2008 | Acer Aspire 3000 Notebook
Touch pad and keyboard freeze after startup
Battery problem, remove battery... fixed!
Feb 19, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 5050-3242 Notebook Logo
1,382 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
