Question about Panasonic Televison & Video
I can't get favorite channels to set up. I didn't realize there would be a charge for help. TV is only 30 days old.
    Problem Solver:
Haven't figured it out yet......will work on it.
Posted on Sep 29, 2008
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
Aug 13, 2009 | Samsung 50 in. Plasma TV
HOW DO YOU SET UP MORE THAN ONE FAVORITE CABLE CHANNEL ?
Dear Customer
Sir/Madam the memory of the content(TV) is to store about only thirty channels so u can not able to store more than that,if in case you want clarifications just get linked with below site which may help you sometimes.
http://www.northjerseymall.com/Mall/CommonPages/contactv3.asp
Thank you
Dec 15, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Static electricity
It's at least conceivable; a long forgotten set we owned used to change channels on its own until I stumbled on to the reason for it and actually had to run a fine grounding lead to the safety ground on a wall outlet. Oddly enough, the static charge was not coming from us but from the high voltage of the set itself that was building up on some metallic trim around the set's channel selector.
If you have any trim of that nature on your set, use some styrofoam bits or onionskin paper and hold it near the trim to see if there is a charge on the set. It may require the same kind of 'fix' our old set needed.
Nov 23, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Only receive 2 channels.
Can you punch in the channel numbers directly to go to the channels, but just not tune to them with the Channel Up/Down buttons?
If so then try tapping the favorite button on the remote until the screen shows "favorite mode off". This mode likes to stay [or perhaps turn] on when you scan for channels, but scanning clears everything in the favorite list except for the channel you are on when you start the scan (so it seems), thus leaving only one or two channels showing up. (This happens whenever I re-scan for digitals.)
To pick out favorite channels, go into the channel menu in the tv menu and with "Favorite: Analog" or "Digital" highlighted near the top, hit OK on the remote to toggle favorite status.
Nov 28, 2007 | Mintek DTV-263 26 in. TV/DVD Combo
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
