Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Wont stay running
Engine only starts with full choke and then dies
  • highmo2001 Sep 29, 2008
    thank you mower runs perfect now
  • froemjose Oct 21, 2008
    • when push brake/clutch pedal to start, engine will run but will shut off when releasing pedal
    Problem Solver:
Hello i think your slow needle jet on the carb is clogged to verify this put few drops of fuel in the carb inlet and try and start if it starts then bobs your uncle your problem is solved just clean the jets . this problem occurs if your engine hasnt been used for a while or some how jets have got clogged hope that answers and resolves your problem Good luck
Posted on Sep 28, 2008
Mine starts, runs 5 minutes, tries to die, runs 5 more minutes (poorly) with full choke, then dies. Carb? Cool?
need vehicle make and year. "Full" choke will always flood the engine causing it to dye. once running reduce choke. Is this automatic or manual choke?
Apr 07, 2017 | Garden
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Briggs and stratton 463707 starts at full choke
Once the engine starts move it off full choke slowly. It will flood the engine if you don't.
Sep 30, 2014 | Measuring Tools & Sensors
How do I find out if the fuel filter is clogged in my 05 Turbo PT Cruiser? After running out of gas (and now with a full tank) the engine starts up great drives for several miles then chokes up and dies. ...
run the fault codes and check for canister purge valve solenoid fault . IF the filter is blocked it stays blocked . What you have is a problem that when the engine requires sufficient fuel there isn't enough and so it dies . After stopping what ever is causing the shortage is relaxed and so it starts and goes until the problem unit is activated again (Vacuum in the fuel tank)
Feb 18, 2014 | 1993 Jeep Grand Cherokee
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
Carburetor?
Try cleaning the carbs. Does the engine run any better with the choke on? If so the carbs need cleaning.
Apr 01, 2010 | 1999 kawasaki ZXR 400
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do i adjust carbuerator
Start your adjustment by turning both screws (gas and air) all the way in and then back them out one and a fourth turn. Start from there. Hope this helps.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
The saw wont stay running. I start it with full choke and throttle but when I try to close the choke it just dies. I can get it to start with half choke, but again it will die when the choke is off. The...
Sounds like the carb needs to be rebuilt. Those tiny jets will clog easily and need to be replaced. The diaphragm is also a large part of bogging and dieing. Hope this helps.
Jun 14, 2009 | McCulloch Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
186 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
