Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 ERROR
I have cleanded the hose and now tring to run a drain/spin there is is one blanket and no soap, the cycle starts with draining and then the SUD error comes on for a few min. the the cycle starts agian w/ draining and then the F 02 error comes back on??
  • 706 Answers
Try cycling the washer a few times without a very small load of clothes and no detergent. I assume that you are and have beenm using only HE type detergent and I suggest you try using about 1/2 to 1/3 the amount called for until your system is purged of any and all remaining detergent in the lines. Here are the manufacturers reccommendations to address your problem..
“SUD” (Suds Routine)
When excessive suds are detected, a suds routine
automatically starts. This routine removes extra suds and
assures proper rinsing of your garments. “SUD” is displayed
during rinsing and at the end of the cycle to inform you that
Suds Routine was activated. Use only HE (High Efficiency)
detergents.
Hope this helps you..
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Posted on Sep 28, 2008
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Suds display and F35 error message
The F-35 is associated with this little gadget here:
Affectionately known an an analog water pressure switch
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fill 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
May 28, 2011 | Whirlpool Washing Machines
Error code f35
F35 (on some models)
WASH CYCLE)
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
Check drain pump.
Apr 19, 2011 | Kenmore Elite HE5t Washer
I am getting a f-35 code on the washer ..what does that mean?
F35
Check if the air trap is not blocked.
WASH CYCLE)
Check drain pump.
Item 20
$86
Mar 17, 2011 | Kenmore HE2 Plus Front Load Washer
Often get an error code "F-35" and or "SUD" on my duet WFW9500TC01 Bill Selby
From my notes:F35
WASH CYCLE)
Check drain pump.
Item 20
What else have I got let's see:
$86
Could just be sediment in the tub.
Blow out the tubing before you order anything.
Make sure the hose is tight.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool deut steam washer Model W10133484A and I got a F35 error
The recommendation is to change this part:
F-35: Analog switch/water level failure.
Item 20
$86
F35
WASH CYCLE)
Check drain pump.
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag washer said suds then f 35. what does it mean do I need it repair?
Some F-35 notes:
F35: ANALOG PRESSURE SENSOR FAILURE
WASH CYCLE)
Item 20
$86:
Keep in mind if too much detergent was used:
Check drain pump.
Jan 04, 2011 | Washing Machines
Hi, My washer does not do the final spin.....Everything else seems to work except the final fast spin. Is there anything i can do?
Stop using so much soap? These newer washer must use a slight amount of HE soap. Any other thing will cause motor over amping, burn up sensors, and cause the control to work overtime trying to remedy the problem. F35
WASH CYCLE)
Check drain pump.
More Here
Dec 29, 2010 | Whirlpool Washing Machines
Stops washing cycle without draining and spinning: gives error code F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 20, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
812 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
