Question about West Bend Coffee Makers & Espresso Machines
Old coffee maker parts
Can you believe I accidentally trashed the basket and stem (the inner parts) of the old West Bend Party Perk coffee pot (12-22 cup, Cat.No. 58122, 60 watts, 120 volts)? You know, those old tan with brown stripes plastic coffee pots that many grandmas used at family get togethers? Any recommendations on where I can possibly find replacements for the lost parts or even an old style pot with the inner parts still inside? P.S. Tried directly to the West Bend Company, but, so far, no luck.
(Yes, I borrowed it from someone's grandmother and now I'm trying to make good on my dumb mistake.) Looking forward to hearing from you - please contact me at  suzanne.sawyer-ratliff@comcast.net
Where can I replacement filters for a 100 cup West Bend coffee maker?
The West Bend Large Capacity Coffemakers do not use replacement filters. The manual for the West Bend 33600 Large Coffee Urn is available here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Use an electric perk or regular grind coffee in the percolator basket rather than a 'drip' or finely ground coffee that would require a filter.
If you require a new basket, please see the West Bend on-line replacement part site here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=946&secid=87&linkon=subcategory&linkid=125
Mar 19, 2011 | West Bend 33600 Coffee Maker
Our Thrift Store received a West Bend "3 in One"
The Instruction Manual for the West Bend 55108 3 in 1 Coffee Center can be found here:
http://www.westbend.com/supportdata/L5563G_55108-3in1_All.pdf
Available replacement parts may be ordered online from these sites:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=4400&secid=87&linkon=subcategory&linkid=115
or
http://www.abtecparts.com/Westbend_coffee_makers.htm
Sorry someone has not responded sooner.
Feb 25, 2011 | West Bend 55108 Espresso/coffee Maker
After it's very first use, and it was for heating plain water only, the basket has large blackened (actually dark grey) areas and spatter patterns, and the floor of the urn around the spout is blackened. ...
I read your question but I am slightly confused... I see that you use it to heat water only, I presume that it is for tea or hot choc. Since you say it is new... Have you always used the perkolator parts? This unit is not designed to work without these parts. There is a thermocouple that helps regulate the water temperature, If the perk parts (the basket and the rod placed correctly in the bottom heating element) there is a good chance that is causing a problem. Try 1/2 pot of water and the parts I mentioned in place (as if you were going to perk coffee) and try it again, I think it will heat correctly and give you satifactory results. As far as the "blackening" it maybe "Brillo'ed or SOS pads to clean unless you have the plastic basket, the metal parts can be scrubbed. I hope I have understood your question correctly. Good Luck!
Douglas
Jan 28, 2011 | West Bend 33600 Coffee Maker
Need a manual for west bend party perk, no. 58030
wont shut off automatically and the light wont go on
Dec 11, 2009 | West Bend 58030 Coffee Maker
36 cup coffee maker
Are you using the correct size paper filter for the basket? Are you putting too much coffee in?
Good luck.
Mar 13, 2008 | West Bend 33600 Coffee Maker
Basket and perk tube
Sure is
see if you can locate the model somewhere on in it
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs !
eric
Mar 01, 2008 | West Bend 13500 Coffee Maker
Coffee Makers & Espresso Machines Logo
173 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
