Question about Motorola Talkabout T5700 AA (22 Channels) 2-Way Radio
T 5700 Walkie with no Talkie
I have these 5700's with brand new batteries and I can't figure out why i can't  hear anything on them. I think I may have a setting set wrong on them. They were given to me by my brother and I don't have any manuals. Can you hepl me out? Walkie with no talkie
  • fiddlindeano Sep 29, 2008
    I found the owners manual but still can't get them to work properly.
    When they are on the same channel I can't get them to transmit, but when they are on the MON they transmit but the reception is terrible.
  • Motorola Master
  • 1,654 Answers
  • eradiostore
    eradiostore Oct 01, 2008
    The Monitor "mon" button is to be used simply to see if others are talking on the same frequency as you. It is a "polite" rule of the FCC. All radios have the "mon" feature. It is not intended to be a continual form of communications. It typically will give a "white sound" noise when depressed.
    If you are needing to press the "mon" button to communication, you do not have your interference eliminator code set properly. Re-read how to set this code, and you should solve your problem.
    Also, watch the setting of the Qt filter. For best results set it to zero.
T4500 motorola walkie talkie power button not working. I have put in new batteries but I can't get it to turn on.
The easiest thing I can think of is to jump out the power switch and short it to a constant on position. > Brands > Motorola Manuals > Two-Way Radio > T4500
Hope it helps.
Aug 24, 2017 | Motorola Radio Communications
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
When turned on, the screen stays red and you can't do anything
You might try contacting Giant Intl. 1-800-638-5119, They produce the radio for Motorola and are able to troubleshoot over the phone or by email. I have read through the manual and did not find anything pertaining to this problem.
Best regards
Nov 13, 2014 | Motorola Walkie Talkies 2-Way Radio
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Will the walkie talkie charge while turned on and left in the cradle? These are brand new models.
Not efficiently. It would take 3-4 times as long to get a full charge, as the energy is depleting nearly as fast as it is charging. The good news is most FRS radios will go up to 18 hours on a charge. Think of the charger as the radio's bed. When you go to bed, put the radio to bed too.
Best regards.
Jan 26, 2010 | Motorola Walkie Talkie 2-Way Radio
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Motorola Talkabout T5700 AA (22 Channels) 2-Way Radio Logo
336 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
