Question about Pioneer SD-643HD5 64" Rear Projection Television
Pioneer sd-643hd loosing grid
I bought the tv used on line. it has been working great for about a year. Recently I have been readjusting the grid on the tv. When I turn the tv off and turn it back on after awhile the grid is messed up. So I adjust it again. Its good for the time the tv is on but I turn it off and its messed up again. Is there anything anybody can tell me about the problem. Should I start looking for another set? Please help the wife said I can't get another one till this one is done.
Please Help
  • 3130 Answers
SOURCE: Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Posted on Mar 28, 2007
  • 1284 Answers
SOURCE: Color Problem on SD-643HD5 (Green is not working)
Either its a bad green CRT or a driver issue to it. In any case not for the novice to fix.
Posted on Apr 24, 2007
SOURCE: Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
Wow, that first link is perfection! I'm worried though. The photo on that link shows the base grid green pattern looking VERY geometrically even with only the red and blue lines off. On my set, the green base grid geometry is off/wavy. Are the IC's the correct fix?
Posted on Jan 26, 2008
  • 3 Answers
SOURCE: "TV Not Turning On"
i have the same tv, all i did was take out the power supply board and reflowed the solder on there. i have heard that this is a common problem with these televisions, but its not too hard to fix (just takes about 2 hours to resolder them all). hope this helps
Posted on Oct 26, 2008
  • 15 Answers
SOURCE: Pioneer projection tv SD-582HD5
I had the same problem, try running the TV on Mute, if it is a bad solder joint the sound can vibrate the solder point and trip the relay, if the TV doesn't trip off with the sound on mute then it is probably the big power transformer's solder connection needs resoldered. sound vibration from those big pioneer speakers may loosen the solder joint over a period of time because the transformer is heavier and bulky and vibrates a lot.
Posted on Sep 13, 2009
Mitsubishi WS55711 TV. 'm OK with a a soldering iron and have done similar repairs in the past but I'm far from an expert. I had a convergence problem and have installed a new convergence...
Since you said replaced a chip, I presume it was the one STK-393-110 which is used in some models--most of their sets use two chips------I know these sets very well.
I have a offer for you---if you have Yahoo IM we can chat there and maybe find your problem.
Here the site emails me etc.
May 28, 2011 | Televison & Video
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Sony Convergence
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Convergence problem
I have a hdtv my red and blue are offset i need to know how to adjust properly
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Pioneer sd-p50a5-k remote does not work on tv
The code will vary depending on the maker of the universal remote control. Purchase a universal remote as they are usually around 15 dollars and try it out. Make sure Pioneer TV's are on the list.
Apr 01, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
64 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
