Question about iLO LCT32HA36 Television
DVD hookup audio visual
When I hook up my DVD player to the back of the TV I get Video but no sound and the cables are hooked up to the audio out holes
  • ahc115 Oct 13, 2008
    Tried all connections possible buy only video comes out,no sound.
  • 903 Answers
Try setting the av to a different channel. Or take out one of the audio wires. Presuming you have checked the connection to the back of the dvd
Posted on Oct 23, 2008
Dvd hookup
It sounds that you are connected the TV with DVD player Via AV cable. In this case, no RF channels won't go. You have to select its AV option. Check it. Refer the user manual for TV.
Aug 12, 2013 | RCA F19251GY 19" TV
Trying to hookup a dvd player model #DX-DVD2
You need 3 RCA plugs... generally colored red, white, and yellow. on the back of the DVD player plug the yellow to video out, the red to audio out (stereo), and the white to audio out (mono). The other side of them goes to the back of the TV... the yellow video input 1, the red audio (R) input 1, the white Audio (L) input 1. Then take the cable service round coax cable and screw it into the back of the DVD unit where it says Coax. Get another short coax cable and hook to back of the DVD unit on Cable out, and the other side to the back of the TV under cable/vhs. And that"s it! Hope that helps you!
Chuck
Jun 23, 2012 | Dynex DXDVD2 Player
Where to hook up my dvd player
U look around on the back of ur tv or the side of the tv u see a 3 holes one YELLOW,one RED, one WHITE hole all lable INPUT in a straight in a role that for hook up to the tv if u are using a RCA component cable Y-Video,R-Audio,White-Audio.The other end of the RCA component cable Y,R,W go into DVD player 3 holes Y,R,W OUTPUT holes.
Aug 27, 2011 | Vizio E370VL 37 in. LCD HDTV
I hooked up a new lg hd tv via hdmi through my digital cable box. I am not receiving true surround sound, only dolby II. I have my box digitally hooked up to the receiver and the HDTV digitally hooked up...
It's possible that the TV broadcast isn't in true surround, and is only dolby encoded.
You can try going back to the component hookups, but I am not sure that will solve your issue.
Feb 27, 2011 | Panasonic SA-HE100 Receiver
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
I have my wii hooked up to the tv, but i cant hook my dvd player up because there isnt a second yellow plug.
Ur tv and DVD player have a S-Video connections ports holes for this wire right?Tries websites like Amazon.com,Ebay.com to buy this S-Video wire to used to do the connections for the tv and the DVD player together by this S-Video wire in tv S-Video and DVD player S-Video connections ports holes for this wire.Use the AV cable RED,WHITE same connections like ur Wii connections to get the Audio.
Nov 08, 2010 | Sanyo DP50747 50 in. Plasma TV
How to hook up a dvd player to a SHARP r19-m100
Ur tv have colors R,Y,W Video,Audio IN holes from the back or the front wright?The DVD player have R,Y,W Video,Audio out holes from the back wright?Used the AV component cable R,Y,W hook it up to the tv R,Y,W Video,Audio IN holes,the other side of the AV component cable to the back of the DVD player R,Y,W holes.Now u are all hook up and ready to play movies.
Oct 20, 2010 | Sharp 19R-M100 19" TV
Digital audio doesn't seem to be detected. I've got directTv hp, and two dvd players hooked up. The input mode is Auto. When DP or analog, no sound comes out. when Auto, I get background noises, but no...
Optical cable from DVR or DVD to receiver. TV to monitor out. Digital audio is only through optical hookup. Then hook your mic up and run the YPAO and set to auto to run the sound basic set up then when done, go back a fiddle with the manual set up and turn up speaker volume, set sound modes, etc
Jul 27, 2010 | Yamaha HTR-5790 Receiver
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
Jul 31, 2009 | Sansui DTV3200 32" TV
iLO LCT32HA36 Television Logo
69 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
