I am trying to install a lexmark 640 series printer to my new compaq laptop with windows vista. I installed the printer using the installing **** that came with and it says it was successfully installed but when i try to print a document nothing happens.
  • 706 Answers
Have you tried going thru the control panel, printers and faxes and selecting ( with the right mouse button) that printer and then properties... to print a test page? or.. have you used the device manager to check that the printer is working properly? To use the device manager, right mouse button MY COMPUTER then selct the Hardware tab and then Device Manager.. You may find your printer listed under Imaging Devices.. Right mouse that and select Properties.. You wil have some options there to update the drivers too.. Hope these tips get you going...
Good Luck..
Posted on Sep 28, 2008
INSTALLATION OF LEXMARK X5250 PRINTER ON WINDOWS 7
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
Apr 09, 2010 | Lexmark X5250 All-In-One InkJet Printer
We have windows vista and when we tried to install compac IJ300 it only goes up to windows 98 - can we install that using vista???
I found this solution on another website, I suggest you give it a try.
Everything works fine since I installed Vista except for my printer a Compaq IJ300 which is a Lexmark Z11 in disguise. I installed the driver for the regular Z11 through the "Add Printer " but had problems.
Went to Lexmark site - downloaded drivers for Z11 Series ColorFine- working perfectly. So far I have no other problems with vista.
Aug 25, 2009 | Compaq Inkjet Ij300 Printer
Broken Lexmark 640 installation disc
Lexmark does not distribute replacement install disk for all models, but many models are available.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Feb 23, 2009 | Lexmark Z640 InkJet Printer
Lexmark all in one printer don't install on vista. is there a patch
You may want to see if the Printer is actually compatible with Windows Vista first before you try anything else.
If your Printer is Listed Below, then unfortunately it will not run on your system unless you format the machine and downgrade to Windows XP. (Or obviously you can wait until the device is supported, but to be honest that could be months, years).
exmark
  • Lexmark Z11, Z12, Z22 & Z32, Z31, Z42, Z51, Z52 - work with pre-installed drivers
  • Lexmark Color Jet 3200, 5700 - work with pre-installed drivers
  • Lexmark X5400, X4200, X1200, Z645, Z840, Z730, X2400, X3400, P350, X7300, X8300, X9300
  • Lexmark X1100, Z500 & Z600 (combined), P4300, X3300, X2300, X7100, Z810, Z700, X5200, P6300, P910, P6200, X6100, X5100, X2200
  • Lexmark 1100, 1200, 2400, 3400, 4200, 5400 Series, Lexmark X7350, X8350, X9350, P350, Lexmark 640 Series, Lexmark 730 Series, Lexmark Z845[4]
Dec 04, 2008 | Laplink Software PCmover for PC
Lexmark 8300
I dont know the exact tip for this one. but you can try the following steps to solve this problem.
Download the Windows Vista printer driver for the SCX-4216F multifunction printer from www.samsung.com.
  1. Install the driver on your Windows Vista computer. During installation, you’ll be prompted to connect the printer to your computer. Choose the option to proceed with installation without connecting the printer.
  2. After installation completes, open the Printers applet from the Windows Vista Control Panel.
  3. Right-click on the new Samsung SCX-4100 Series printer and choose Properties.
  4. Go to the Ports tab.
  5. Click Add Port…, select Local Port, then click New Port…
  6. For the port name, enter exactly the network path and share name of your printer (e.g. \\RECEPTION\Samsung SCX-4×16 Series).
  7. Click OK, and double-check that this new port is selected with the checkbox next to it.
  8. Click OK to close the printer properties.
Jul 21, 2008 | Microsoft Windows Vista Ultimate Edition
My windows vista Business cannot install my Lexmark X83 All-in-one printer!
Lexmark is not officially making any driver for the X83 that will work with Vista because its a 32 bit printer and Vista is 64 bit. Sounds like some BS to me. So, I have the same problem, a perfectly working printer and an incompatible OS. My Mom was using an old mac and had an X83 printer which she loves. She now has a new PC running Vista. Only now, I have the problem of how to get the X83 to work with Vista. Supposedly the lexmark 5200 drivers will work. My suggestion is to power off and unplug the USB cable to the X83, and manually remove any driver(s) related to it that may have been installed using the system control panel device manager. Then attempt to install the xp driver for X83 per the post below. I'm going to then plug in the USB cable and power up the printer and see if it works (it probably won't) but I'm hoping it'll then cue itself looking for the 5200 series drivers which supposedly do work according to one post on MS forum, I quote:
"After reading all these posts I was both discouraged, but more determined than ever to get my X83 to run on Vista. I have to say the determination payed off! That's right...I just both scanned and printed 7 pages on my X83 running on Vista!!!! Here's what I did. I first installed the XP driver for X83 hoping I could dumb my laptop down to make it run on an XP version....no luck there, but when I did that, my laptop recognized the X83 as a Lexmark 5200 series which is also an all in one. I thought, well, if that's what it wants, that's what I will give it. If you go to the Lexmark website and look under downloads/drivers, there is a list that shows all compatible OS. The 5200 series is listed here with a Vista compatible driver. Once I downloaded it and went through the installation wizard....it worked LIKE A DREAM!!!! I hope this helps all of you as I also understood and felt your frustrations! Good luck!!!"
article source http://forums.microsoft.com/technet/showpost.aspx?postid=503767&siteid=17&sb=0&d=1&at=7&ft=11&tf=0&pageid=1
Lexmark 5200 series drivers http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
xp driver http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 you'll have to type in a search for the driver enter X83 in the field, follow the steps...
Apr 21, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x 1185 on windows vista
icannot conect my lexmark x1185 to my compaq vista
Jan 07, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Connecting printer to Windows Vista Laptop
I have a new HP laptop with Vista Home OS, and I just installed my HL-1440 with a driver that was installed automatically in the "New Printer" procedure in Windows, and it works perfectly.
--Gabriel
Nov 25, 2007 | Brother HL 1440 Laser Printer
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
