Question about Microwave Ovens
GE JVM150001 Microwave
Cooks intermittently runs fine. Door switches all meter test ok. Testing the 2 thermal switches one tests open one closed. Magnitron open Hood closed. Seems correct?? Was hoping all sensers should meter open....
Any ideas?
Willaim,
I have gone through the testing on the Mini Manual and still have intermittant operation. When I turn the oven on there is a secondary humming noise that indicates the oven is working. I can tell at once if the seconday hum is not there. When the oven starts that econd hum sort of kicks in a second or two after the oven starts. 6 months ago I seated all 4 of the door switches and the oven worked non stop for like 6 months. All of a sudden it went out again like before. Is there more to testing these switches than just continuity or no continuity? Can they be partially bad?
I was going to retest all switches for resistance and connections, as well as Magnatron and other high voltage connections per your Blog
Thanks,
Rwood
Posted on Oct 06, 2008
  • Microwave Ovens Master
  • 9,098 Answers
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Can you scan and e-mail or photocopy & fax the "schematic diagram" portion of the mini-manual to me?
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
fax 866-481-2802
Posted on Oct 04, 2008
  • William Miller
    William Miller Oct 13, 2008
    This model may utilize a triac to control the cooking power. If so, that's another wild card in the mix.
    If this is a problem in the triac circuit, it's pretty important to catch and fix it before it fails hard and smokes part. When that happens, you can't get part values and the whole board would have to be replaced.
    Since you found the mini-manual, would you scan and e-mail or copy and fax (in detail mode) at least the "schematic diagram" page to me?
    If it does not have a triac, I'd say you have a bad switch or two. If they've never been replaced, you can probably count on it. And / or possibly a failing relay or connection on the control board.
    If you only need a switch, you can order one from us for $5 postpaid.
    It's actually best to replace both the primary and secondary switches. But the schematic will help me figure that out for you.
    We regularly repair control units for
    customers nationwide by mail for $39.95 postpaid in about a week.
    William E. Miller
    prototech@usa.net
    free fax 866-481-2802
I have panasonic nn-gs597m microwave its working normal but not heating, I opened the cover magnetron is hot the fan is working. Any help?
follow the next steps , use the VOM and fix it. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Jun 16, 2013 | Microwave Ovens
Code f-33
Step 1:
Symptom: Intermittent or continuous error code F33 on the display. Cause: Insufficient (poor) grounding of the controller (DP) board.Remedy: clean the groundHowever if Not Heating proceed with the next steps.
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 07, 2013 | Microwave Ovens
Neff gmbh microwave on but not heating
Step 1:
follow this steps and test and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Step 4:
Maytag 4205baw runs but does not heat any items
Step 1:
Follow this steps and see the diagrams.God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Feb 06, 2013 | Microwave Ovens
Why is the microwave not heating the food, but the turntable is hot.?
Step 1:
folloq this steps and fix it. God bless you
1)Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Step 2:
Step 3:
Microwave not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout , and the fan replacing parts that don't pass the test.
Oct 16, 2012 | Kenmore Microwave Ovens
Advantium 120 not working
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout, and the fan, replacing parts that don't pass the test.
Oct 15, 2012 | Maytag MMV1153A Microwave Oven
Maytag microwave problem everything seemingly works but does not heat. Help
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
My microwave is brand new. When I close the door, the dish rotates and the light stays on. Help!
Test 3 Door Switches. Intermittent, Skipping, Maybe Burnt internally or Spade contacts Burnt. Door switches should Open/Close or Closed/Open. A Meter or Continuity Tester Works. Audible Sound Hearing Helps on Continuity Tester. Listen for Nice Clear open-Close or Close-Open sound. If no Sound or Skips ( Intermittent ) Just found Your Problem. One of the Door Switches is Not working right. Now You Can Make & Save Money by Doing it Yourself.
Aug 15, 2008 | GE Microwave Ovens
Microwave Ovens Logo
483 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
