I goes through the process with messages like vlan none pri none/ iftv server not.../L2& Boot not available...TFTP server unavailable... Help!
SOURCE: Looking 4 a TFTP server for upgrades
There must be a tftp server on your network, that must have files on the server that are needed top upgrade the firmware. Ask your admin, as they will have the IP address. I can refer you to a tftp program you can install on a server, if need be.
SOURCE: Main unavailable
The network switches must be set up to allow the phone to connect to the phone system. You should contact your vendor for this support.
SOURCE: main unavailalbe resetting phone
Hello Roshani Ameresekere,
Welcome, and thank you for using FixYa!
To answer your question: Your phone has lost connection to the VOIP network.
These types of phones use DHCP to assign an IP address to themselves from your VOIP network, usually by means of a switch or router. When they lose connection to this switch or router, they cannot communicate with the VOIP network and load their network environment, called PXE. This in turn loads the phone.
Try replacing the patch cable on the phone between the phone and the wall. If that doesn't resolve your issue call your Telcom Specialist who installed the VOIP Network. He will need to test the phone, switch, Firewall, and VLAN to make sure the phone hasn't died or his configuration hasn't been hosed in the router or VLAN. He may also need to reset his VOIP box.
Have a great day!
hope this
helps
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
??????????????????????????????????????????? hope this helps
