Question about Bose (321GS) System
Bose 321 I have sound, but no picture
I believe, by mistake, that I selected the PAL option. Now I can't see a picture and can't get to the settings menu. Any ideas???
Click settings
arrow down 3 times
click enter
arrow down twice
click enter
arrow right
....should put it back in NTSC mode
Posted on Oct 27, 2008
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
No picture but sound i need to put my system back on ntsd?
click settings
arrow down 3 times
click enter
arrow down twice
click enter
arrow right
....should put it back in NTSC mode Good luck and God bless!
Mar 21, 2010 | Bose (321GS) System
Will not get sound when hook up to the optical input.
try going into the settings and select optical source. select whatever source your using.
Oct 27, 2009 | Bose 3·2·1 II System
My child messed with the settings on my 321 bose
Reset all EQ settings to 0 for a starter. It sounds as if it is EQ'd down all the way.
Jul 05, 2009 | Bose 321GS Series II System
Bose 321 Series III Lateness
This depends on the source. If this happens internally (from a DVD in the 321) then the problem should be able to be resolved by just resetting the 321. (unplug the power cord from the sub for 30+ seconds) -If this is from external sources like a cable box, believe it or not, you can reset the cable box the exact same way. If resets don't fix this (and this is external) then check the cable box's settings for a/v delay compensation.
Jun 19, 2009 | Bose 3 2 1 GSX System
Bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Apr 12, 2009 | Bose 3 2 1 GSX System
Movies only play in black and white, could the video chord have gone bad?
The video cord could be bad or it could be loose at the 321 or your TV.
There could also be an incorrect setting in the system menu of your 321.
The unit must be on NTSC not PAL. With the series II and III systems you may also need to designate what type of video cable you are using. You will get a B&W picture if you are using a component video cable but the system is set to composite.
Oct 12, 2008 | Bose 3 2 1 GSX System
Lifestyle 38
Its very simple just press the "pal" button again until you see the "pal" icon comes up
Sep 16, 2007 | Bose Lifestyle 28 System
Bose (321GS) System Logo
1,167 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
