Question about Nikon D80 Digital Camera with 18-135mm Lens
Dirt speck I have a dirt speck that appears in all of my pictures in exactly the same place. I think it is in the camera, not the lens. I have thoroughly cleaned hte lens. Is there a way to clean the camera's imaging surfaces or do I need professional service?
  • laurakushner Oct 02, 2008
    I got it. The swab worked. I had some used for high end electronics work that a friend had given me. I am good to go. Thanks.
It is probably a speck of dust on the sensor. Get a blower from any camera shop, remove the lens,lock up the mirror (mirror lock up in camera menu) and give the sensor a good blow ( without touching it) while holding the camera front down so that any specks of dust fall away from the sensor. Sometimes specks can stick (pollen for example) in which case you could try a disposable swab and cleaning solution, although if unsure most camera shops provide the service pretty cheap - the sensor would be a lot more expensive to replace if you mess it up.
Posted on Oct 01, 2008
Disassemble, clean and reassemble Nikkor 85mm f1.4 AIS
Don't even think of disassembling it yourself!!!!!! Take it to a professional camera repair man and save yourself allot of money. I guarantee you that if you disassemble it yourself, you will not be able to reassemble it and the repair man will charge you much more then if you just brought him the lens in the first place.
Why do you think that the lens needs to be internally cleaned in the first place? It is very rare for so much dirt to penetrate the lens's interior that it actually affects the quality of the photographs. Don't over react to a few specks of dust between elements. The most important element to keep clean is the exterior surface of the rear element because that is where the light is most concentrated. Let a camera repair man tell you if your lens really needs such a drastic approach.
Dec 12, 2013 | Nikon Normal AF Nikkor 50mm f/1.8D...
Line appears in the screen after photo
If there is the line appearing in the saved/download picture then it can be relative of the following:1. check the lens for dirt or speck of dust that can impose a shadow.2. Possible fault in the optical sensor- the CCD.3.The battery bulge must be checked and if there is lower voltage then it must be replaced but is not related to the fault.4.Fungus within cannot be ruled out and should be checked out and cleaned only if you are equipped to remove the lens assembly.
Mar 12, 2012 | Samsung L700 Digital Camera
I have a black spot on the screen of my camera. It does not appear on the photo but is very much in the way when I take pictures. The camera is an Olympus 4030. Can this be fixed/ How expensive is it?
This can be also a minor issue of a speck of dirt on the optical sensor- the CCD. So if you are able to open in clean surroundings , use the correct tools to do so . open and check the lens carefully for dirt , check the sensor unit. If dirt is seen use lens cleaner to wipe off dirt .
If not it can be fault in the CCD and must be estimated.
Jul 09, 2011 | Cameras
A blob is appearing on every frame could that be dirt on the sensor? If it is dirt on the sensor, how do I clean it?
First of all, you can't get to the sensor to clean it. Is the blob in the same place on each picture? Is your lens clean? Does the blob actually appear on prints you make?
Dec 24, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Pentax SMC D 16-45 Lens How to clean inside? Pictures are showing spots and all the outside lens have been cleaned along with the inside of the camera itself. Can not see the spots when taking pics only...
Your lens would need to be absolutely filthy with enormous dirt specks to cause the fault you describe. Dust, fingerprints, and regular minor debris simply doesn't show in the final image. In any case, you cannot clean inside the lens without dismantling it and that is a job for experienced specialists only.
Your fault is a dirty image sensor. You can buy sensor cleaning kits, but if you're inexperienced with them or trying to clean the sensor in a dusty environment you'll just make matters worse. Many camera shops offer sensor cleaning while you wait at relatively low cost. The reason you don't see the dirt when taking the picture is either because you're looking through the optical viewfinder or because the LCD screen simply doesn't magnify the image enough to show the marks which are present in the image.
You can prevent the dirt from reoccurring by never leaving the camera with the lens throat open for more than strictly necessary, and by always trying to keep the open lens throat pointing slightly down when swapping lenses.
I hope that I've helped, please take a moment to rate my answer.
Sep 16, 2010 | Pentax *ist DL Digital Camera
Black at the bottom of the pictures
Possible causes :
1. dirt or dust in camera or lens
2. dirt on sensor
3. sensor is cracked
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
May 30, 2010 | Nikon D50 Digital Camera
I got some dots in every pictures i have taken and it's all on the same spot. what are these? is this a pixel problem? can it be fixed?
Not quite enough information for solve.
have you printed these pics and seen the spots?
whayt happens if you print it on a different printer.
Are these dots visible on the preview of the camera?
It could be moisture spot ore dirt inside ofthe camera or even the lense itself Sometimes bacteria will grow inside the lense.
Inspect the lens itself, as well as the mirror insie the camera to see if there is dirt or speck on them.
Please rate our help to keep the FREE sevice online ++++ Thank you for using FIXYA
Sep 07, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Clean dust inside the lenz
Don't. Unless there are some really big specks of dirt inside the lens then they will have no effect at all on picture taking. To prevent the problem getting worse always store your lens with it's front and rear caps on and inside a lens bag. Also make sure that your camera bag is clean and isn't shedding fibres from the inner linings.
Dismantling your lens to clean it is really a job best left to a professional who will then additionally check and clean/lubricate the moving parts inside the lens.
Jul 03, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Dust in my Kodak m863 lcd screen
Hold the camera upside down and gently blow off any grit and lose dust particles. Next lightly wipe the lens with a few drops of lens cleaning fluid, place the fluid on the lens cleaning paper, not directly onto the lens and then wipe the lens.
Feb 04, 2009 | Kodak EasyShare M863 Digital Camera
2 ISSUES: 1) Pencil tip size dot in the middle of the projection. 2) weird smell coming from projector vent.
might be a speck of dirt on your lens, possibly on the inside. I assume youe have wiped the outside of the lens? ;-) (I have to ask) If the dot seems to be following pixels exactly your projector might be broken. The smell might be from some dirt or possible an insect in the projector. Try using compressed air to blow out any dirt and dust. It might just be dirt acumulated over time that is burning to create the smell. t t might be a long shot, but if the bulb is easily removed, yo ou might try to shine a flashlight through the lens to see if there is dirt on the lens inside. If you adjust the image size mechanically, or use lens shift, does the speck move on the picture? If so, it's probably on the lens.
May 17, 2007 | InFocus ScreenPlay 5700 Multimedia...
Nikon D80 Digital Camera with 18-135mm Lens Logo
137 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
