Hitachi 50UX58B 50 in. Rear Projection Television
Problem for Hitachi 50UX58B 50 in. Rear Projection Television
Hitachi 50UX58B
By Duke - usenet poster
MY WAS WATCHING HITACHI MODEL 50UX58B AND IT WENT DEAD.
I CALLED HITACHI TV CO. THEY GAVE ME THEIR REPAIR SERVICE PHONE NUMBER. THEY CAME AND TOLD ME THAT FUSES ARE BAD AND NEED A NEW REGULATOR AND GAVE ME ROUGH ESTIMATE OF $ 250. HE WENT TO SHOP AND FAXED ME ESTIMATE OF $ 428.83. HE WROTE "IN DESCRIPTION OF WORK TO BE PERFORMED " NEEDS POWER SUPPLY REPAIRED. I ASKED HIM TO GIVE ME BETTER DETAIL SO I CAN COMPARE APPLE TO APPLE. HE SENT ME ANOTHER ESTIMATE AND TOLD ME THAT THEY HAD EXCATLY THE SAME TV NEEDED NEW POWER DEF PWB AND GAVE ME ESTIMATE OF $ 805.92 HOW CAN YOU TRUST THIS TECHNICIAN WHAT DO i DO ?
I ORDER THE BOOK AND FOUND OUT ( D940 B-120 SERVICE LED WAS OUT ANDD946 TV9V WOULD COME LITTLE BIT LATER.
i DO NOT KONW HOW TO PROCEED FROM HERE. CAN ANY BODY HELP ?
Same Problem
Apr 21, 2008
-   I have similar problem. No power one day. When I connect power supply to board several green lights come on then 1 slighter brighter green light comes on as set gives 'crackle' sound then all slowly dim out but constant red blinking light near power supply stays on.-   bdoon
Best Solution
posted on May 30, 2006
Helpful)
Putty
Rank: Apprentice
Rating: 0%, 0 votes
Dead - Replace c707 and e994
power light blinking fuse open Replace C707 (1000pF/2kv)
No power, power supply geen led light on then shuts off E994 protecter 2Amp open. C707 SHORT
No power Replaced open protector E994 and blown C707
A place to start.
Was this helpful?
Yes
No
Solution #2
Helpful)
kioner
Rank: Apprentice
Rating: 0%, 0 votes
is there a red led glowing, and are the green leds out?
if you have red and green leds which of the green ones is out?
Was this helpful?
Yes
No
Solution #3
posted on May 29, 2008
Not Rated)
ciws14
Rank: Apprentice
Rating: 0%, 0 votes
Is can the c707 be changed easily with the board still in the tv? The C707 in mine has a burn mark through it and I have the replacement. It looks tricky to get in there with a soldering iron and replace. Should the board be removed or can it be done without removing the board? I am also confused as to the discharging of the residual power. It has been unplugged for a couple of days, but I did not understand the diagram on the front cover to discharge the system. Any advice? Thanks!!!
Was this helpful?
Yes
No
Popular Solutions for Hitachi 50UX58B 50 in. Rear
Questions and Unsolved Problems for Hitachi 50UX58B 50 in. Rear
Do you recommend Hitachi 50UX58B 50 in. Rear Projection Television?
Answer
Answer
wwood51375 yes those components can also affect the color. I tried answering your question but they... (More)
Answer
screen has a double image. looks like the green gun is bowed at the top and bottem of the screen.... (More)
Answer
50ux58b had lost poewr, red light went out never came back on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 50UX58B 50 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
