Question about Acer Aspire 3502WLCi Notebook
DVD drive doesn't work
The dvd drive doesn't work anymore on my Laptop. it shows as dvd drive(E) on "My Computer" but once a disk is inserterted it doesn't read it. Would it be the rive itself of a bios setting problem. Device manager says that it is working properly??
  • g-atlantis Sep 30, 2008
    I tried these suggestions but still no luck. Thanks for your assistance though. I guess I will have to look for a new dvd drive for it.
  • 169 Answers
It's likely that you have a bad drive. Before rushing out to buy another one, remove the device for CD/DVD drive under Device Manager and restart the computer. Let Windows reinstall the driver and see if that helps.
Additionally, you might want to completely remove the drive, check the connections on the end, and also use compressed air to blow out inside where the connection is made.
If after all that, still not working ...bad drive :(
Posted on Sep 29, 2008
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
My dvd drive doesn't work
If it happens for only one particular disk:
Bring that disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it happens for all disks:
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jul 31, 2012 | Acer Aspire 5738Z Drivers Recovery Restore...
Dvd not working on my E-SYSTEM sorrento 1
A couple troubleshooting steps.
Power the laptop off and remove the battery. There will either be a single screw on the back of the laptop or a spring button next to the DVD tray. Push the button to pop out the DVD player or remove screw, stick a paper clip in the tiny hole next to the DVD eject button and pull the DVD drive out and then firmly push the drive back in to verify it isn't seated all the way. Now put the battery back in and power on the laptop. Enter BIOS and check through the menus and ensure the DVD drive is not disabled. If you have followed these steps. Refer to the next section.
If you answer yes to any of the following you will need to replace the drive.
  • When you press the button, the drive does not light up or open
  • When you put a disc in the drive it doesn't detect the disc.
  • The DVD drive doesn't show up in device manager or under "Computer/My Computer"
If in device manager you see a yellow ! or ? on the DVD drive you will need to restore the computer because the driver corrupted and typically you can't repair them.
Jul 18, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Laptop DVD
Try cleaning the DVD drive with compressed air, if it still does not work try cleaning the drive with a DVD disk cleaner. if it still does not work and the software for the DVD drive has been confirmed as operational then the drive is dead and needs replacement.
Jul 07, 2009 | HP Laptop Keyboard for HP Pavilion DV6000...
right clik on my computer go to properties then hardware then device manager then find dvd rom drives then uninstall it .after uninstall it right clik any icon there then clik on scan for hardware changes.then it search if found any device simply clik next ..if not found turn off sytem .then check your cpu that dvd is connceted proter to mother bord.check data cable and power cable of dvd reconnect it.
then restart the cpmuter yout probelm is most of solved.
Oct 05, 2008 | Everex StepNote NC1500 Notebook
Acer Aspire 3502WLCi Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
