Question about Microsoft ChiMei CMV938D 19" Widescreen LCD Monitor
Monitor problem visuals are slightly elongated on the monitor screen.
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Posted on Oct 02, 2008
My dell monitor model #1800fp diplay is elongated for all pictures I display on the screen. How do I correct this
should be on the menu on front of monitor ,,with options to change that,,and check control panel on cpu,,make sure its set rght,,for widescreen or regular
Nov 03, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have an AOpen Motherboard model number MX46-533GN and have just purchased an HP2009v monitor which uses a 1600x900 resolution. I can only adjust the display to 1024x768 which gives a slightly elongated...
The latest drivers are available on AOpen's site here. This may not help you, though. The high resolution your new monitor needs is more than the integrated video hardware can deliver, and the drivers can't change that. You will need a replacement video card.
The motherboard has a 4X AGP slot for video expansion. Many cards are available from many vendors. Here are a couple of examples from Tiger Direct: one card. another card. If you're outside the US, you can find vendors closer to you.
Apr 13, 2010 | Computers & Internet
My pictures are too "long" that is, faces are elongated. y monitor is new and I can't figure out out to "fix" the pics.
change the resolution of your screen to match your monitor, Does it look ok in 1024 x 768? have you set it higher than this?
Oct 27, 2009 | BenQ FP731 17" LCD Monitor
Black edges to individual lcd cells
Sounds to me like the screen is starting to go bad. Best way to find out though, try another known working monitor and see how that works. If the other monitor works well then you know the original monitor is the problem.
If the 2nd monitor gives you problems then you know its the video card thats bad at that point cause you would be having the same problem on both computers.
Jul 04, 2009 | Dell ? SP2009W 20" Widescreen Flat Panel...
How to alter the geometry of an Acer AL1715 monitor. Circles are oval, elongated vertically
Go to Start, Control Panel, Display, Settings. Select screen resolution. Don't pick as wide of a screen.
Apr 02, 2009 | Acer Computers & Internet
Flat monitor doesnt boot
I think the problem is with the capacitor....you need to change the capacitor...
Mar 24, 2009 | ViewSonic VA1912w 19" LCD Monitor
Screen is off-center
hi there if you press the menue controle button you will come to the main controle screen and scroll down till you see the adjust horizontal aaand press the button again now you will be able to move the screen left or right and set it to your liking then press the button 1 more time and you will be able to exit the controle screen
Feb 18, 2009 | KDS Visual Sensations 551 (White) 15...
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Horizontal / vertical deflection failure
The solution to this problem was to replace the sony part #CXA2043Q on the D Board.
Oldpilot
Dec 03, 2007 | Dell UltraScan 1600HS D1626HT 21" CRT...
Computers & Internet Logo
194 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
