Question about Electrolux Freezers
Freezer bubbling coming from top of freezer inside
We have a leak bubbling inside the freezer. Is this dangerous?
  • 943 Answers
Hi thanks for the question .when the fridge shuts off the freon is boiling in the freezer that's what makes it cold is the boiling so what your hearing is normal you don't have a leak thanks the appliance doc
Posted on Sep 28, 2008
What is the orange light for on unidentified freezer?
If that orange light is on the front of the freezer, on the top or bottom, it is very likely a light telling you the freezer is not cold enough inside, and the food is in danger of spoiling.
It may also be a "on" light.
If you will find a freezer thermometer and put it inside, you can tell whether it is an "on" light or a warning light.
Usually freezers run temperatures of about 10 degrees Fahrenheit or lower if they are working correctly.
God bless your efforts.
Feb 11, 2016 | Freezers
Bad smell from fridge (not mouldy food)?
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Mar 25, 2014 | Freezers
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
We had a freon leak, I wondering do we need to throw all the food away that was in the freezer??
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
Dec 05, 2010 | GE Freezers
Freezer not making ice
In cases freezer not making ice .is that the tube maybe have leak causing to escape the freon gas. or bubble is in the tube not allowing the freon to circulate or the compressor is defective.
Jun 25, 2010 | Freezers
Ice if forming along top gasket area and side of freezer where
If we have ice on the inside of the freezer it means air is being pulled into the box somewhere. The most likely place is the door seal, it sounds like you already checked it, but I would suggest that you look very close at the bottom and aides of the seal too, it could be leaking in air from there. Check the inside liner for cracks and seal them if you find any. Look at the corners of the cabinet to make sure there is not room for air to come in.
Air leaks will lead to frost, it is just hard sometimes to find where it is leaking in.
Apr 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer running bout only freezer top of freezer
Either the compressor is failing or it has lost some freon which means there is a leak. The sealed system needs serviced.
Eric
Sep 15, 2009 | Woods Chest Freezer C1501W3
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bubbling sound coming from the bottom of my freezer
There is a vacuum build up in the freezer compartment when you close the door. This can make the door difficult to open. You can overcome this by sticking a small lollipop stick to the bottom part of the door gasket. This will act as a vacuum breaker.
Mar 06, 2009 | Whirlpool Upright Freezer EV161NZRQ
Freezers Logo
106 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
