Question about Sony Cyber-Shot DSC-S40 Digital Camera
Images all lines and stripes on monitor and photos
Good battery, didn't drop camera, was fine, pushed shutter button by mistake while menu icons were up. Now all rainbow distortion in lines and stripes. Clarity gone. Please help!
Put the right batteries in... I had same on my camera...Lines and distortions but sine i use uniross rechargeable 200mah the problem has disappeared. go o www.uniross.com to get them. Saved me buying a new camera...
Posted on Oct 11, 2008
When trying to take a picture or record a movie, the screen is a solid light pink.
try an sd card from another source. the format function of the camera should be used to prepare the sd card for the camera before you take pics with it. this may be a format issue with nintendo. format will erase all images on card, so save them first somewhere else.
Jun 14, 2013 | Cameras
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Camera wont turn on in the photo mode. batteries are fine and canview stored images. Do you know whats wrong? tks
You said batteries are fine and you can view the images. Sometimes a battery needs to be top shape to get the camera fully going.
this company can do a great repair and is very reliable.
http://www.teleplancamerarepair.com/Fujifilm_FinePix_S5700
when you send your camera in make sure to include the battery so they can test it out and make sure it is providing the full energy needed.
Jul 16, 2010 | Fuji FinePix S5700 Digital Camera
Casio EX-S600 digital camera takes good photos, but the display is really ghosted with a very faded picture and vertical color bands through it. It worked fine earlier today and has not be dropped. Any...
First verify that you didn't just accidentally turn off the LCD. To check, turn the camera on and press the "DISPLAY" or "DISP" button once. One other thing to check is that faded pictures can sometimes be caused by a stuck shutter. Potential symptoms may also include purple scratchy lines showing up on the LCD monitor and the camera's pictures. Other reported symptoms may be extremely distorted images (one reader likened them to the movie "Grudge"). Or blank or black pictures or black videos with good sound being recorded on the camera's flash card. You may suspect that the camera's shutter is not opening, but this is not the case. Note that the camera's menu functions should show up without any problem. Please note that your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. Note that they're going to look for dings and dents. This is a CCD failure and in some cases had been subject to a recall. Contact Casio support-this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you!!
May 19, 2010 | Casio Exilim EX-S600 Digital Camera
How to upload pictures on a vivitar 3750
Generally the auto timer is under the setting's when your already in picture mode with the camera on. Sometimes it can be found on the camera in the form of a hotkey on the back or side
Apr 14, 2010 | Vivitar ViviCam 3750 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
Nov 19, 2006 | Nikon D70s Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
100 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
