Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Tensioners there is a grinding noise coming from behind my point cover how do i change the tensioners. help i can't afford to pay someone to doit. It's 2002 springer softail twin cam 88.
  • 91 Answers
The tensioners are spring loaded and the springs are real tuff the fiber pad is another story the cam cover comes off easy a gaggle of 3/16 allen bolts the adjuster is on the 7:00 position turn it insert a small allen wrench or nail thru the adj, into the small hole in cam plate to hold it in the loose position pop out old one insert new one
Posted on Jan 03, 2009
2004 sebring 2.7 has grating noise when cold. Engine is quiet once it's warmed up. One mechanic told me belt and tensioner need to be replaced. Another told me this is a internal noise common
Cams are WELL known for knocking on these engines. It isnt a sticky piston ring or timing. The cams have a wear point on the lobes and will make noise till warm and the oil is warm. I habe worked on many of these engines. Best bet is to run a good oil and a little heavier year around like 10w 30 high mileage oil. Even lucas oil additice helps with the noise because it doesnt drain down like oil and keeps the lodes and lifters oiled better.
Oct 30, 2014 | 2004 Chrysler Sebring
How do I replace the chuck in my drill? It is making a grinding noise.
Chucks DON'T make grinding noises!!!!!
The grinding noise is probably coming from the REDUCTION GEARBOX which is located behind the chuck [the shaft upon which the chuck is mounted comes out of the gearbox].
There are usually four (4) screws mounting the gearbox housing/cover onto the motor/handle section of most drill/drivers.
The cause of most grinding nioses originating in the gearbox is lack of lubricating grease between moving parts.
Jun 02, 2013 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
My 2002 ford expadition is still making the grinding whoop whoop noise, I took it to a machanic and they said it was the roter or brakes or ball joints, so I got all replaced on both sides and it is still...
If the noise only happens when you are moving, and it changes with the speed of the truck, its something that is connected to the wheels.
Road speed does not affect suspension noises like ball joints and spindles.
So it would be something like the brakes, axle joints or bearings, or something in the differential where the axles come together.
If the truck is 4wd you have front hub bearings behind the brake rotors, and regular bearings if it is 2wd.
Apr 08, 2013 | 2002 Ford Expedition
How do I pin point a loud squealing noise coming from the belt side of a 2002 Dodge Caravan with 3.3 engine?
you have a bad tension pulley my son has same vehicle ,and it was doing the same thing ,till he changed out the tension pulley good luck
May 06, 2011 | Dodge Caravan Cars & Trucks
4x4 light keeps coming on and off and this eventually caused the vehicle to make a really loud grinding sound to the point that I cannot drive the vehicle anymore what can I do I cannot afford to pay a...
this sounds alot like my 04 f150. if it has the iwe vacuum axles then likely the problem is the 4x4 solenoid. on the f150 it is on the passenger strut mount behind the batt. the new parts have a water shield to prevent ingestion. they cost about $20-30 very easy to change under 10 min. you likely would also need to change the iwe on the passenger side. again fairly easy to change but involves removing the ball joint and tie rod end to get clearance to it..
Dec 31, 2010 | 2004 Ford Explorer
My 2006 ford taurus has a loud grinding noise coming from one of my pulley's. I have the squeakey sound too, that I think is coming from the tensionor pully that is common with ford's. The grinding sound...
The tension pulley on the Ford products is famous for wearing out. If you are positive about where the noise is coming from, then the only real solution is to purchase a new pulley from the dealership. Installation involves removing tension from the serpentine belt, unbolting the old pulley and installing the new one. Put the serpentine belt back in place and you are done. I have tried in the past to lubricate those pulleys both on and off the car - it never worked for any length of time. Seems like once the bearing is worn to the point of making noise there is no saving it. Let me know if this helps you out or not.
Apr 27, 2010 | 2006 Ford Taurus
Grinding noise on 2002 Olds Bravada
Try making tight turns to the right and then to the left. see if the grinding noise comes and goes. It could be your C/V joint and they need to be replaced. The noise will only come when your making the tight turns, you don't have to go fast. Walking speed will do and you can hear it with the window open or someone walking beside the Bravada. Good luck and keep me posted. Be glad to help.
Jun 16, 2009 | 2000 Oldsmobile Bravada
Harley davidson how to change tensioners
If you have chain Tensioners then you have a Twin cam. This is NOT a job for an amature. Its necessary to take out Push rods which means remove heads or cut your pushrods and reinstall adjustables. You need to take out your cam plate,re align oil pump..Its not a simple job for a novice. If you have noise they have already exploded or are about to. Do not ride your bike..those plastic pieces can get sucked into the oil pump and do major damage. I told that to a customer that was going on a trip he did not heed warning. He got 75 miles they exploded and he bought a new motor.
Sep 28, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Harley davidson how to change tenttionners
Is your bike STOCK?? Have the Cams been changed? Do you have Stock Cam CHAINS & TENSIONERS, or is it updated to GEAR DRIVEN Cams? Either way, you have a Cam and or Lifter Problem, and if you are not a Harley Mechanic with access to Shop type tools and Equipment, then I suggest you take you Harley to a reputable repair shop for diagnosis and repair. DO NOT CONTINUE TO RIDE WITH THIS PROBLEM, IT WILL NOT FIX ITSELF and will only cause you MORE EXPENSIVE DAMAGE. Good Luck! -Dr.Mark
Lands Phones Logo
147 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
