Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Images are too fat looking or spread out on my 22" monitor, how do i adjust so the images appear normal?
The images are fat looking or too spread out. If I rotate the pic or image on the screen 90 degrees then the picture is thin......Can you help me adjust?????
  • scotttesta Jan 09, 2009
    reinstalled xp and my objects look 'fat" was not like it on last install
You need a video card that will adjust the resolution to the proper proportion. The closest I can get to a good aspect ratio is 1152 x 864.
Posted on Oct 16, 2008
Monitor screen is perfect , but there is one 1mm lightgreen color line appear verticallly in the screen...
It would appear that the monitor is going bad. If it is within a year of purchase, contact dell for a warranty replacement. If not, use it until it dies. It depends, but usually bad pixels and lines like this will spread rather quickly.
Jun 15, 2011 | Dell E2210 22" Widescreen Flat Panel...
My Acer 22" wide screen
change the resolution on the pc to 1024 x 1024 and then increase one size bigger each time till you find the correct one. Click start > control Panel > display settings then click settings change it in there (XP)
Apr 17, 2011 | Acer Computers & Internet
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
Jul 04, 2010 | LG Flatron W2242P-SF 22" Monitor
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
People ALL look FAT...
Haha , hi .This has got to do with your Aspect Ratio , Google your screen to see how to set it back to normal , it will look fine afterwards :D
Dec 29, 2009 | Acer 22" X223w LCD Monitor
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
How to fix 22 inch Acer hiorizontal distortion when set at max re
right click on your desktop... select properties.... when that window opens ... click on the tab that says settings. you will see a sliding adjustment there with different screen sizes.... experiment abit till you get the screen size that looks right and that you are comfortable with.
Mar 26, 2009 | Acer AL1914B (Black) 19 in. Flat Panel LCD...
Distorted images due to wide screen
Your entire desktop is probably stretched left to right.
You need to adjust the resolution of your computers video card in the display properties to one that the widescreen will accept correctly.
There is a chance that your video card may not have the correct resolutions available. If this is the case then you may be stuck with this view until you change coputers or video cards.
to get to display properties based on win2k or xp
Right click in the center of your desktop, choose properties, go to settings and there you should see the resolutions available. Try different ones till you find a good one, you may have to settle for one that is close to your monitors setup if the exact one isn't available.
If using a laptop with a standard screen with the wide monitor, you may need to disable the laptop screen and use just the monitor to get the correct resolution on the monitor.
Oct 13, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
631 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
