Question about Kitchen Ranges
We are getting an f1 code on a stove. what does this indicate?
  • labee52 Sep 29, 2008
    We are having the same problem....the alarm beeps and the display reads F 1 . We hit the cancel button and it stops, but is happening more frequently now. No owners manuel...don't know the model number.
    Bee
  • john gagnon
    john gagnon May 11, 2010
    hi i need the make & model # thanks
  • 943 Answers
Hi well it says in the code book that its the membrane &touch pad .probably expensive. thanks the appliance doc
Posted on Sep 29, 2008
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
My Kenmore stove when I try to bake the oven shuts off and i get a code of E1-F1-
Hello there
Your kenmore product is a whirlpool product actually. The error E1-F1 indicates that the Electronic Range Control/Clock has been blown. Replacing this piece can easily cost you $150+. but is not too hard to replace ok?
Hope this helps
Best regards Mike
May 11, 2011 | Kenmore Kitchen Ranges
What does F1 fault code mean?
Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jan 08, 2010 | Kitchen Ranges
Whatt is an F1 fault on the kenmore stove
HI, This code is indicating that the main control board has failed. This will require you to have the damaged circuit board replaced, asap. This type of damage that has occur, is not repairable. The board must be replaced.
F-1 - Board Failure.
Dec 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Stove stays on and 30 min. later it starts beeping and F1 code
An F1 error code indicates a faulty keypad and /or ERC electronic control.
Jan 02, 2009 | Frigidaire FEF366 Electric Kitchen Range
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
