Question about Coleman Powermate Powermate 5000W Generator
Looking for manual for generator...won't start
I have a Coleman Powermate PM0612023.9.... it will not start. It cranks, but won't turn over...looking for manual...please help. Thanks in advance.
I had the exact same problem. There a few things you need to do first.
1) Make sure the fuel line knob is turned to the Open position; this knob is located under the gas tank.
2) Turn the power switch to on : it is a little red switch located near the pull-handle on the front of the generator. It needs to be on 'I' not on 'O'
3) Turn the choke lever on: it is a little steel lever with an arrow at the tip. Move the lever in the direction the arrow is pointing.
4) Make sure you have gas left in the tank: it may have evaporated or gummed up if you did mix in a fuel stabilizer before putting it away for storage.
If none of these things work , then you carburator may be full of water and gas lines gummed up.
These Gens need to be started up at least once a month to make sure they keep working properly.
Fred
Posted on Nov 19, 2008
It is one year old but only used twice. New gas. Was working. Is getting fire. Wants to start just won't turn over. Not sure if I'm missing a step like a switch or something. Was working 6 months ago.
Posted on Oct 08, 2008
    Problem Solver:
  • 13 Answers
In order to help, first of all coleman went bankrupt about a year ago, im gonna give you the web site
http://www.powermate.com/contact.php
you may can find what your looking for. If you can give more detail, like, is it new out of the box ,second hand, was it running before, new gas, old gas, is it getting fire ,what have you done so far Etc. i may be able to help you get it running
thanks, troy
Posted on Sep 29, 2008
  • 3 Answers
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Coleman powermate generator won't generate
Check rotor again and measure to see if you have DC voltage on the brushes while running. If no then suspect capacitor
Nov 11, 2012 | Coleman Powermate Powermate 5000W...
Misplaced User Manual for Coleman Powermate 6250
I would run a search on line for your model number. I will look and let you know.
Feb 02, 2009 | Coleman Powermate Premium Plus 6250W...
I cannot crank my coleman powermate generator.
If the engine will not crank-if it has an electric start, first check the battery and connections to the starter and ground. If the battery is good and the connections are clean and tight, then I would check the ignition switch. If it clicks once when the key is turned to the start position, check for a seized crankshaft (see below) If it does not click, then it could be the starter, solenoid, or the ignition switch. If it has a manual pull start, and it will not pull, check to make sure the crankshaft can turn freely and if not, disconnect the pull starter and check it again-if it turns freely the rope start mechanism is hung up-it must be freed up before you can pull start it. If the crankshaft will not turn at all you probably have a serious problem that will require a major teardown.
Jan 29, 2009 | Coleman Powermate Powermate 5000W...
Looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Sep 26, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
1,610 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
