Question about Mitsubishi WD-73833 73" HDTV
Blue lights won't come on when TV is turned on, can't get ge the on/off selected to control it
Blue Glow light on/off can't be highlighted, help! thanks Judy
  • bulleys Sep 28, 2008
    We solved the problem----the TV has to be set to high energy----then to av --then to blue light control! Thank you to the folks who work on Sunday! Judy
Hey FixYa! Glad you asked----annoying problem----simple solution. MENU-Setup--Highlight Energy--Fast Power, Click on, AV---Blue Glow, Click one of the On choices. Judy
Posted on Sep 29, 2008
Truck wont start, but only if you hear a click
I copied this from my GM service manual for 1982 6.2 diesel.
1. If the glow plug relay is not clicking on and off then turn the ignition to the RUN position and connect a 12V test light to ground and touch the pink/black wire in the glow plug relay connector.
2. If the light is off repair the open cicuit in the pink/black wire to the splice.If the light is on then touch the light blue at the glow plug relay connector.
3. If the light is off replace the glow plug relay. If the light is on, disconnect the connection at the thermal controller and touch the black wire in the connector.
4. If the light is off, repair the open circuit in the light blue wire from the thermal controller to the glow plug relay. If the light is on repair open circuit in black wire back to a splice. If no trouble is found replace the controller.
You should also get your hands on this Haynes book. Diesel Engine Repair Manual, part # 10330. Excellent coverage on the 6.2 and 6.5. In it, they say that early 82\'s have a hole at the number 2 hole on the pin connector of the wire harness for the thermal controller. this allows dirt in there and corrodes the pins. Remove the connector and clean thoroughly the pin area on the connection and controller. Seal the hole with some silicone. If things are still acting up, replace the wire harness connector.
Hope some of this helps.
Jan 19, 2014 | 1983 GMC C1500
Have a hl61a750a1fxzc(model) tv, tv is about 5 years old. Tv has a greenish picture tint... Looking at top 7 colors on my tv...
please do this test: God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Aug 01, 2013 | Samsung Hl61a750 61" LED Powered DLP HDTV
My polaroid tv has a red light on but the blue light won't come on and there is nothing displayed on the screen
you must read your instruction manual in section troubleshooting for to what is this problem.
Otherwise you must go to Polaroid to get support help online with Chat.
God bless you
May 10, 2012 | Polaroid 899-KS1-GF4012XAPH TLX-04011C...
Blank screen with blue light
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
HP3500 all colors are printing too light - black is gray, blue is light blue, red is pink, etc. All cartridges are full, no error message on printer
Calibration is a printer function that optimizes print quality. If experiencing any print quality problems, calibrate the printer.
  1. Press (Select) to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CALIBRATE NOW .
  7. Press (Select) to select CALIBRATE NOW .
  8. Wait for the printer to calibrate.
that should solve your problem
Aug 12, 2010 | HP Color LaserJet 3500 Printer
Westinghouse tv won`t turn on. blue light is lit
westinghouse flat screen light on lower part...can not get to stay on tv and no sound...what button so i push to go back to tv
Feb 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Is there a way to shut off blue light
Hi my name is Eric,
I hope I can help you with your issue ,
Yes you can turn off the annoying blue power light, go into the menu and look for the item called blue eye effect on/off
Press the MENU button.
Press the ▲ or ▼ button to select “Setup”, then press
the ENTER button.
2 Press the ▲ or ▼ button to select “Blue Eye”, then press
the ENTER button.
3 Press the ▲ or ▼ button to select “Off” or “On”, then
press the ENTER button.
• Off : LED(Blue) will not come on when you turn the TV
on and off.
• On : LED(Blue) will come on when you turn the TV
on and off.
4 Press the EXIT button to exit.
If you feel good about my solution please click accept.
If you have more questions you can still respond,
I will reply asap
Sep 14, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Mitsubishi WD-73833 73" HDTV Logo
205 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
