Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley davidson how to change tensioners
Grinding noise in side points cover
  • 2 more comments
  • v2iper
    v2iper May 11, 2010
    What year Harley and Model
  • Dr. Mark CycleSurgeon
    Dr. Mark CycleSurgeon May 11, 2010
    What year is your FatBoy? Is your Ignition system STOCK or AFTERMARKET?
  • Brad Hurt
    Brad Hurt May 11, 2010
    Tell what yr model and engine and I may be able to help
  • Carl Navarro
    Carl Navarro May 11, 2010
    Whats wrong with it :-)
    Scholar:
  • 150 Answers
If you have chain Tensioners then you have a Twin cam. This is NOT a job for an amature. Its necessary to take out Push rods which means remove heads or cut your pushrods and reinstall adjustables. You need to take out your cam plate,re align oil pump..Its not a simple job for a novice. If you have noise they have already exploded or are about to. Do not ride your bike..those plastic pieces can get sucked into the oil pump and do major damage. I told that to a customer that was going on a trip he did not heed warning. He got 75 miles they exploded and he bought a new motor.
Posted on Jun 14, 2009
2 Suggested Answers
SOURCE: harley davidson how to change tenttionners
Is your bike STOCK?? Have the Cams been changed? Do you have Stock Cam CHAINS & TENSIONERS, or is it updated to GEAR DRIVEN Cams? Either way, you have a Cam and or Lifter Problem, and if you are not a Harley Mechanic with access to Shop type tools and Equipment, then I suggest you take you Harley to a reputable repair shop for diagnosis and repair. DO NOT CONTINUE TO RIDE WITH THIS PROBLEM, IT WILL NOT FIX ITSELF and will only cause you MORE EXPENSIVE DAMAGE. Good Luck! -Dr.Mark
Posted on Jan 26, 2009
Ironhead Primary side knocking sounds when idle?
Hi Lasse, could be the springs after you torque the compensating bolt/nut try turning the compensating spring pack cover by hand if it moves you need new springs and I am sorry you can't find the first and best tool you ever bought for your Sportster but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day. Harley Davidson Manuals Mark Workshop
Aug 23, 2015 | Motorcycles
Ironhead 74 xlh primary knocking sound at idle.
Hi Lasse, for more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Harley Davidson Manuals Mark Workshop
How to remove the transmission cover on the right side
Hi Anonymous, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
You need to pull the entire transmission. Have nice day.
Aug 28, 2013 | 2005 Harley Davidson FLHT - FLHTI Electra...
2006 street glide flhx. noisey valve train .geting worse.only 20.000 miles .just started in the last 2000 miles. are push rod ajustable? how can you tell if cam teniture is bad?
The stock pushrods are not adjustable. Screamin' Eagle pushrods from Harley are adjustable. To check the cam tensioners, you have to remove the cam cover on the right side of the motor to see the tensioners. You will need a flashlight to see the tensioner on the back side of the cam plate. If the plastic on the tensioners show excesssive wear, replace them. They typically need replacement after about 30,000 miles, but I've replaced them at 20,000 to 60,000+. I just put new ones in my Fatboy at 32,000. Have you recently changed from conventional oil to synthetic? This can give you a bit more valvetrain noise, due to the thinnner synthetic oil.
Dec 06, 2012 | Harley Davidson Motorcycles
2008 road king classic I have a tick sound on left side?
Does it sound like a chain noise, coming from the primary case?
In 2007, Harley changed the primary chain tension adjuster to an "automatic", spring loaded one, that doesn't work very well.
You can bolt in an older manual adjuster, BUT the area that USED to be an inspection/access cover on the outer primary cover is now a solid area, so you'd have to remove the outer primary cover everytime you adjust the primary chain.
There are some aftermarket "automatic" adjusters out on the market.
May 18, 2012 | 2008 Harley Davidson FLHRC Road King...
Growling noise out of the primary cover in netural on a 2006 dyna superglide
When was your last service, check the tension on the primary chain tensioner and check with your manual to see the proper setting. Also go to your dealer and get a new gasket for the cover plate first
Jul 26, 2011 | Harley Davidson FXD Dyna Super Glide...
Grinding noise when transmission is in neutral
That noise may be coming from your primary, not the tranny. Try adjusting the clutch, and (of course) make sure you have the correct amount of chaincase fluid in your primary. If that doesnt do it Change the trans fluid and see if that helps
Nov 11, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Tensioners
the tensioners are spring loaded and the springs are real tuff the fiber pad is another story the cam cover comes off easy a gaggle of 3/16 allen bolts the adjuster is on the 7:00 position turn it insert a small allen wrench or nail thru the adj, into the small hole in cam plate to hold it in the loose position pop out old one insert new one
Sep 28, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Harley davidson how to change tenttionners
Lands Phones Logo
129 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
