UNABLE TO CONNECT TO EBAY WEBSITE
Sounds like you may have a virus. Are you able to access other web pages?
If so,First, you will need to disable all viruses from loading at startup:1. Turn on your laptop.2. As soon as you see anything on the screen, Tap the F8 key once per second3. Select safe mode and hit ENTER4. Once you log into Windows, go to start -> run -> type: msconfig -> hit enter5. Select "services" tab -> check "hide all microsoft services" -> then "disable all"6. Select "startup" tab -> "disable all"7. Click OK and Restart
After loading Windows normally, download and run Hitman Pro 3.51. Download: Hitman Pro2. Scan using quick scan.3. Setup page: select "No, I only want to perform a one-time scan ..."4. If it finds anything, select free cleanup.
Once your computer is clean. Restore msconfig to normal:1. go to start -> run -> type: msconfig -> hit enter2. In the General Tab -> select "Normal Startup"3. Press Ok and Restart
best regards,abdielcomputer repair plantation
