Question about Health & Beauty
Oster Golden A5 Clippers
I just bought these clippers to clip my horse. They worked fine the first day. After using them, I brushed the excess hair off, cooled them off, and put them back in the case. Several days later, I pulled them out, put a little oil on the blades and tried to use them. They are not cutting at all.HELP!!!!!!!!!!!!!!!!!!!
  • 191 Answers
Try running the blade for a bit keep lubricating in between the blades its important to oil your blades during and after use to avoid rust build up on the cutting surfaces. Also just make sure the blade is engaging onto the clippers ok.
Posted on Apr 25, 2009
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
Hi where can i sent my clippers to get repaired
Many people send clippers to www.angliaclipperservices.com most parts are in stock for Oster, Andis, Aesculap, Moser/Wahl, and horse clippers, the turnaround is only a week.
Jun 17, 2011 | Oster Golden A5 2-Speed Universal Motor...
I have oster 6550 series a clippers, i installed new blades but they hardly clip any hair, when I loosen the tension the blades "move quicker" but vibrate with a loud noise
the tension should be pre set from the factory, if its more than one blade your having problems with then its likely there is a problem with the clippers.
Mar 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Can get it right
Jun 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Feb 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Health & Beauty Logo
270 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
