Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley davidson how to change tenttionners
Grinding noise in side points cover,2002 springer softtail 88 twin cam
    Problem Solver:
  • 11 Answers
Is your bike STOCK?? Have the Cams been changed? Do you have Stock Cam CHAINS & TENSIONERS, or is it updated to GEAR DRIVEN Cams? Either way, you have a Cam and or Lifter Problem, and if you are not a Harley Mechanic with access to Shop type tools and Equipment, then I suggest you take you Harley to a reputable repair shop for diagnosis and repair. DO NOT CONTINUE TO RIDE WITH THIS PROBLEM, IT WILL NOT FIX ITSELF and will only cause you MORE EXPENSIVE DAMAGE. Good Luck! -Dr.Mark
Posted on Jan 26, 2009
How do you deactative the alarm on a 2009 springer softtail cvo
Hi, Ray for more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. http://www.cvoharley.com/smf/index.php?topic=33852.15
How do disable my alarm Twin Forum Harley Davidson Forums
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Apr 24, 2016 | Motorcycles
I have a 2002 HD Heritage Softail Classic with an intermitent growling noise in the lower front end of the motor. It is louder when the engine is cold. The noise disapates when riding. Had all the fluids...
I don't work on the Twin Cam engines but I'll take a guess on this one. Your Softail is equipped with the Twin Cam 88-B engine. The engine is a counterbalanced engine that is different from the standard TC88 engine. The counterbalancer is located in the lower front of the engine cases. Go to this site to see what it looks like and where it's located. http://www.bikebandit.com/2002-harley-davidson-softail-heritage-classic-flstci/o/m11509#sch608106 This may be where your problem is located. Keep in mind that I'm not a Twin Cam mechanic. I work on the Evolution and earlier engines and I'm not very familiar with the TC88-B engine but if the mechanics are stumped, I can't do any worse.
Good Luck
Steve
Aug 03, 2011 | Harley Davidson FLSTC Heritage Softail...
I am looking for a service/repair manual for a 1991 Harley Davison Springer with preferrably an 1340 engine. Can also be a 1350, 1440, or 1450 engine.
If you find a factory service manual, it will be for an 80 cubic inch (1340 cc) engine only. In 1991, all Big Twins came equipped with the 80 c.i. Evolution engine. The Twin Cam 88 c.i. (1450cc) engine didn't come out until 1999 in most of the Big Twin bikes and 2000 in the Softail bikes. Try this site for your manual. http://www.diyrepairmanuals.com/products.asp?cat=14142
Good Luck
Steve
May 02, 2011 | Harley Davidson FXSTS Springer Softail...
2006 softtail springer what are the best products for oil and oil filter change
harley davidson have there own brand of oil you can use, but usualy only available from the dealer. I would recomend Penzoil, or Penrite 20W50, with a genuine harley oil filter.
Aug 26, 2010 | 2005 Harley Davidson FLSTC - FLSTCI...
What do i set my points at on my 1997 harley softail
Your 1997 Softail is not supposed to have points. Harley changed over to electronic ignition in 1979 on the Big Twins. But, if you do have points, set them at 0.018-0.020".
Good Luck!
Steve
May 18, 2010 | 2000 Harley Davidson FXSTS Springer...
Location of washers on front axle 2002 harley springer softtail
You need to be sure it is a washer and not a shim. The washer(s) will go on the nut side of the axel outside of the fork, shims will go inside the fork to center the tire.
Jun 13, 2009 | 2002 Harley Davidson FXSTS Springer...
Tensioners
Drain the primary and remove the primary chaincase cover. There are 2 bolts with lockplates and washers thats hold the shoe. Remove them, install the new shoe, reinstall the 2 bolts. The lockplate is installed outside of the washers. Thats it
Sep 28, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Tensioners
the tensioners are spring loaded and the springs are real tuff the fiber pad is another story the cam cover comes off easy a gaggle of 3/16 allen bolts the adjuster is on the 7:00 position turn it insert a small allen wrench or nail thru the adj, into the small hole in cam plate to hold it in the loose position pop out old one insert new one
Harley davidson how to change tensioners
If you have chain Tensioners then you have a Twin cam. This is NOT a job for an amature. Its necessary to take out Push rods which means remove heads or cut your pushrods and reinstall adjustables. You need to take out your cam plate,re align oil pump..Its not a simple job for a novice. If you have noise they have already exploded or are about to. Do not ride your bike..those plastic pieces can get sucked into the oil pump and do major damage. I told that to a customer that was going on a trip he did not heed warning. He got 75 miles they exploded and he bought a new motor.
Lands Phones Logo
190 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
